Author Topic: Auto box 'gear lever'  (Read 1865 times)
slowlysafelysurely
« on: 03 December 2006, 21:05:11 »
Not sure if thats what you call it! but the lever on my 3.0 has a lot of movement when in any position. In other words it goes in to 'gear' fine, drives fine, but if for example it is in drive I can move the lever back and forward at least half and inch.
Any ideas?
Cheers
Re: Auto box 'gear lever'
« Reply #1 on: 04 December 2006, 13:30:51 »
Spunds slightly excessive, there should be some movement.
Loo nder thecar and at the side of thebox you should see a linkage with a bolt through it, check its tight.
slowlysafelysurely
« Reply #2 on: 04 December 2006, 16:09:59 »
cheers, will do, when it finally stops raining!!!!!
Page created in 0.009 seconds with 17 queries.
