Author Topic: Odd one - slight pull to the left  (Read 7721 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
« on: 05 December 2006, 21:15:15 »
Okay here goes, it'll be a slow and steady one this.
Mini-facelieft 2˝L (R reg) many miles (c.167k)
Symptons.  A slight pull to the n/s, about the same under a rolling stop and a sharp brake.  Appears to  be more noticable at slower speeds.
Tony has seen the car a few times now and is happy it is not geometery related - the figures do not show why it might be a 'lefty'.  Also proven not to be pneumatic.
Last year had replacement track rod ends for MOT.  Droplink changed to stop 'clunking' over minor pot-holes (so much quieter).  New wishbone bushes forward and rearward both sides as front worn (a lot).  New shocks as one was weaping a bit (and mileage).  Coils look unbroken.
Steering idler appeared 'worn' but now "tightened" by otherwise reliable garage.
Measured ride height okay - although clearance at front arches seem tight.
So this is foxing us all.  Tony can't see why it pulls.  My garage man can't either (thinks it can only be setup).  I've run out of bits (and money) to change.  The only other things I can add is that it appears to have occured after the front 'bone bushes were changed (or I've only be able to notice it since).  Yesterday I found an empty, even area to play and there are no knocks on full left or right lock but there was the odd cluck/groan and at one point I thought it was all square again until it hit the real road/s and was back to the slight left pull.  Someone else drove it and thought it was easier to pull onto full lock to the left than the right (can't be much in it as I hadn't noticed); but despite being set up centred the wheel is rh down about 5 degrees.
Minor after-thought.  Whilst otherwise slight, this car has, previous to my ownership (I hasten to add), been in a somewhat minor (cw others) frontal argument.  That said, Tony thinks the car is straight and would spot if the chassis was not quite how Vauxhall made it.
Has anyone;
a) experienced of this, and preferably the solution
b) got any really good suggestions
c) want an otherwise nice motor - now with expertly fitted parking sensors (although the buzzer is temporary sited).  It is *not* gold, it is platinum!
d) want to sell me an nice clean v6 (with all the statuary done) motor for not too much - PX?
Re: Odd one - slight pull to the left
« Reply #1 on: 05 December 2006, 21:17:08 »
If idler worn, these cannot be 'tightened' and must be replaced.
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #2 on: 05 December 2006, 21:27:23 »
Thanks.  What I'd thought but didn't say.
Could this be the cause of my ills though?
Markjay
  • London
« Reply #3 on: 05 December 2006, 22:38:48 »
Has anyone;
a) Yep, both my Omegas over the past 8 years were pulling to the left...  :)
b) None whatsoever  :(
c&d) Non and no
Tony had a go at mine as well and couldn't figure it out, he finally suggested swapping-over the two front wheels and believe it or not it did the trick... well it still pulls ever-so-slightly to the left, but if I wasn't looking for it because of past experience I wouldn't have noticed.
My view is that all Omegas pull to the left, don't know why and don't care what everyone else says, they just do!
Welcome to the club mate….
Alas, no more Omegas....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 06 December 2006, 09:30:55 »
yp mines is getting this too - narrowed it down to happening after i changed two rear tyres and had rear brakes done.
Dont think they are related but its MOT time later this month and i will investigate it soon, i do know its needing some geometry work.
No one got an Omega that pulls to the right?
Glenn
  • Oxfordshire
« Reply #5 on: 06 December 2006, 11:02:01 »
I have the same problem, was perfect until I changed the front wishbones and didn't re-track until the next day, one trip to work with tracking out scuffed the inside edge of the RH tyre, has pulled slightly to the left ever since but is getting better as the tyres wear more evenly.
There's a lesson in there, I've learned it now !
« Reply #6 on: 06 December 2006, 14:28:21 »
Every omega I have ever owned has had a small left pull. As long as it's not severe, and does not occur specifically just under braking, I wouldn't be too concerned if it's all been checked out.
Markjay
  • London
« Reply #7 on: 06 December 2006, 16:35:58 »
Every omega I have ever owned has had a small left pull...
Finally.... I am not mad after all  ;D
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #8 on: 06 December 2006, 19:57:24 »
It is driving me mad.  If the car appears 'straight', nothing else is worn (the steering idler was tightend at its bolt/s and now has no or little play in it), has been setup geometery wise, had the tyres swapped to eliminate, what else is left (apart from the pull).
« Last Edit: 06 December 2006, 20:02:36 by JohnM »
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #9 on: 06 December 2006, 20:37:01 »
Mine's a lefty.  Noticed mainly 20/30 mph after going over rise in the road - I put it down to the camber but other cars I've driven on same stretch are fine.  Tyres wear evenly and no issues on motorways so apart from 4 way tracking I just live with it.
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #10 on: 06 December 2006, 21:27:30 »
This (newly added) poll is biased !
- bit cheeky that.
- and I want added in:-
"... and is driving me nuts (and I want my money back anyway)"
then I'll partake; well just stick me in 'as pulls too much to the left far more than it ought too and is driving me nuts (and ...)'  :)
Kaycee
  • Doncaster
« Reply #11 on: 06 December 2006, 21:33:24 »
Hi John
Had the same problem  i cured it by just  tweeking up the freeplay on the steering box. there is a adjusting bolt on the top of the box but make sure it is in the straight ahead position and the engine NOT RUNNING and just slack of and nip it up that will take up the slack and just for an afterthought i run the the camber setting at -1.20 nearside and -1 .10 and the car is as straight as a die incidently this info came from a gentleman who is the tech manager from avon tyres who said one of the problems with omegas is the genourus steering tolerances
Robert
There is a tide in the affairs of man if taken at the flood will lead on to greater things
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #12 on: 06 December 2006, 21:56:07 »
Robert,
Thanks. Just looking at my prints and they are not making too much sense at the moment (too late).  I've noted your figures and I'll ask Tony if mine can be set similar.  I bet your camber figures took out any drift.  I can't place the box adjustment right now - did you have much play at the steering wheel before the tweak?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #13 on: 06 December 2006, 22:00:59 »
As most roads have a camber to the left, are we being paranoid?
I haven't voted.
I like red cars
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #14 on: 06 December 2006, 22:17:12 »
I haven't voted.
;D
They can still get you even if your not ...
This is too much of a pull, unless the car is right over the crown it climbs back!
Still, some bits to go on.
