Author Topic: Fuel gauge prob?  (Read 3121 times)
Taxi_Driver
Fuel gauge prob?
« on: 02 December 2006, 18:19:26 »
When my fuel tank gets to around 1/4 tank.....when i first switch on it can show empty (with warning light on) and very slowly creep upto 1/4......doesnt always do this....and never if ive got more than 1/4 tank.
Earlier when i went out in it......gauge showed 1/4 no probs straight away....
But i did go to the co-op  ::) When i got back in .....gauge went to 1/4 and then dropped straight to empty (with warning light on) and very slowly crept back to 1/4 tank again.
Any ideas? Its not really a problem.....just a pain and if theres an easy fix.....i'll have a go  :y
Cheers
« Last Edit: 02 December 2006, 18:47:37 by Taxi_Driver »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Fuel guage prob?
« Reply #1 on: 02 December 2006, 18:27:16 »
Stay away from supermarkets, you know how much trouble AA has there.  ;D
TuBy's new whipping boy.
« Reply #2 on: 02 December 2006, 18:32:16 »
Float problem maybe?
Actually, I seem to recall a TIS article about floats getting caught and misreading under certain situations...
Taxi_Driver
« Reply #3 on: 02 December 2006, 18:32:36 »
Guess i'll have to start food shopping online then  ;D
It also sometimes does it when parked outside my house......should i move house?  ;D
Taxi_Driver
« Reply #4 on: 02 December 2006, 18:44:38 »
Is that a back seat out job? to access float under a cover?......seem to recall on other cars ive had thats how to get to it.....but dont know on an omega estate  :-/
If its under the spare wheel area.....then it'll be a no no and just live with it....as theres a lpg tank in there....and i aint taking that out  :(
« Reply #5 on: 02 December 2006, 18:48:12 »
In boot area on saloon, dunno about estate :(
Could also be duff connection somewhere as well - instrument panel not connected properly etc...
  • Online Online
Re: Fuel gauge prob?
« Reply #6 on: 02 December 2006, 19:12:28 »
Cheers
My fuel gauge always seems to be in the red!  :(  Average is 24.6 mpg & going down slowly. Infact I've just got 14 miles left on the tank but couldn't face the queue at Tesco's on my way home from work this afternoon!
« Reply #7 on: 02 December 2006, 19:15:44 »
I seem to recall the earth on the estate being near the passenger side rear light cluster....worth checking.
The access plate for the sender/pump is in the boot floor in front of the spare wheel well.
Taxi_Driver
« Reply #8 on: 02 December 2006, 19:22:48 »
If i had TIS, which obviously i dont... it might say the fuel sensor is in the same place....on estates/saloons.....but im not convinced this is the right sensor....as it goes on about rev counter increments.....dunno  :-/
Did have the instrument panel out about a year ago to replace blown bulbs.....but ive not any other prob with anything else?  :-/
Taxi_Driver
« Reply #9 on: 02 December 2006, 19:31:45 »
Ahhh cheers Mark.....Now i have played with that area....when i fitted rear parking sensors...its where i got the earth from when i fitted them..so i'll double check i didnt leave anything loose  :y
Failing that the access point is in front of the spare wheel area   :y....i'll have a poke around there next....just got polystyrene in the way there!
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #10 on: 02 December 2006, 21:47:50 »
Mine does it when low on fuel (30-40miles) and I start it up & set off in a hurry - ok if I'm nice to it though and fine next time started up. :-[
But fast getaways aren't your style, so more likely to be the earth.
Taxi_Driver
« Reply #11 on: 08 December 2006, 21:08:59 »
Checked the earth today....nice and tight  :y.....next step i guess is check the sender wiring
Gwilym
  • Bridgwater, Somerset, UK
« Reply #12 on: 09 December 2006, 15:56:28 »
Cheers
Mine does the same. I just ignore it and routinely fill up around 250 miles which seems to get about £45 so plenty left but with unreliable gauge don't want to take the risk
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
