3.2 Breathers
Started by jiffle, 09 December 2006, 21:41:49
jiffle
Hi all,
there are a couple of Maintenance Guides on here dealing with cleaning the breathers and removing the plenum chamber on V6 engines.  These seem to deal with the 2.5 and 3.0 engines.  Is there any difference with the 3.2.
Also is there any easy way other then taking the system to pieces to find out whether the breathers actually need cleaning, eg does the oil discolour quickly after a change or are there any other tell tale signs.  Other of course than leaking rocker box covers!
Cheers for any help
Mike
[size=10][/size]
Similar method for cleaning - you have extended plenum, so need to clean both sections of plastic bit....
They WILL need cleaning ;)
