Author Topic: 2.2 Running Temp  (Read 2391 times)
2.2 Running Temp
« on: 20 December 2006, 16:47:36 »
A while ago i posted about my running temp because someone was asking about their V6 running hot, just to clarify this is what my 2.2 runs at temp wise:
Normal motoway cruise, around 82/3 ish... The needle sits fractionly above 80 and never moves on a motorway run.
In town (stop start) goes up to 90. Never goes above that though, 90 is as high as it goes.
Takes around 5 mins to heat up usually just under 80, then running normally slightly above,  :y
mar892ree
  • Northampton
  • if it dont undo, hit it wiv an hammer
Re: 2.2 Running Temp
« Reply #1 on: 20 December 2006, 17:06:21 »
Urmmmmmmmmm yea !!
Mine heats up quite quick, normal temp at 84-85, motorway sits at 84-85 and around town ocassionaly hits approx 91-92 when the fans roar in to life and VERY quickly bring temp down to 84-85 again
Mark
« Reply #2 on: 20 December 2006, 17:09:32 »
My MV6 runs around 94 ish.  In this cold snap, its around 92.5.  Once it reaches around 96, fans bring it down...
mar892ree
  • Northampton
« Reply #3 on: 20 December 2006, 17:10:41 »
nice n HOTTTTTTTTTTTTTTTTTTTT
You could do your toast on the way to work  LLOLL
« Reply #4 on: 20 December 2006, 17:28:13 »
v6 runs hotter - thats why midpoint on gauge is 95, as opposed to 85 on those missing to cylinders...
    • E250 Est / Elroq
« Reply #5 on: 21 December 2006, 08:16:40 »
Sounds right to me
The wife's runs about 5oC lower than mine
Taxi_Driver
« Reply #6 on: 21 December 2006, 18:59:39 »
Sounds good to me Tunnie  :y
Mine has been sitting at 82 ish on the motorway the last couple of days....but then its hardly been above 0C outside .....usually sits at 85C on warmish days on the motorway
90 is usual for mine doing town work.......once saw it hit 95C but was in summer when outside was about 30C
So nothing wrong with your thermostat it appears  :)
« Reply #7 on: 21 December 2006, 23:09:32 »
mine runs exactly the same as yours on the motorway TD  :y
So no problems there  ;D
old cruiser
  • Slough
« Reply #8 on: 23 December 2006, 11:37:37 »
My 2.2 running Temp' is also the same as yours, just taking a bit longer than normal to warm up with this cold snap.
Cheers
Pete
