Author Topic: back up or main alarm?  (Read 1779 times)
bigall
  • merseyside
« on: 23 December 2006, 23:58:39 »
Getting the alarm going off about 10 mins after a journey.
all indicators flash and alarm/horn sounds for a couple of mins then only flashing indicators for another couple of mins thensstops.
I can also stop the alarm by  remotely unlocking the doors and locking them again.
Does this sound like the main alarm system or the back up alarm ?
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Markjay
  • London
Re: back up or main alarm?
« Reply #1 on: 24 December 2006, 00:51:42 »
Could be either, but with backup battery failure usually also get an occasional 4 beeps when you leave the car.
Alas, no more Omegas....
« Reply #2 on: 24 December 2006, 10:45:48 »
From my experience, if its the horn sounding rather than power sounder, it's less likely to be a battery issue...
Taxi_Driver
« Reply #3 on: 25 December 2006, 21:24:57 »
Its not the power sounder going off....thats a siren
Its the main alarm if horn sounding.....check the bonnet switch.....this might not be properly upright.....failing that....can you get it read on a tech2, that will tell you which alarm sensor is causing the prob.
« Reply #4 on: 26 December 2006, 00:31:38 »
On some, and no apparent way of knowing, it requires carpass to read alarm codes (rare). On some, it just requires carpass to clear them... (common)
bigall
  • merseyside
« Reply #5 on: 26 December 2006, 18:04:44 »
Thanks for all info - looks like the main alarm - took car for run opened bonnet tapped down switch locked car 15mins later off goes alarm  The funny thing is when the alarm goes off if I turn alarm off and on by key remote then it doesn't happen again until after I take the car out on a run.
Looks like I'll have find someone with a tech2 to identify the fault or even pay a visit to vaux dealer and I bet they don't give post-Xmas sale bargains for use of tech2
Thanks again for help and ideas.
