Just done my breathers
Started by Taxi_Driver, 31 December 2006, 12:12:40
Taxi_Driver
Decided not to wait until tuesday.
Took about hour, 20 mins spent trying to get those dam clips off, im sure someone puts them on in a position that you carnt get clip pliers on to them on purpose  >:(
Atho a bit oily they wernt blocked and no crud either......but did use a tin of carb cleaner cleaning them out anyway.
I reused the gasket for the metal tube, but will fit the new one when i get it.
And ive noticed something......that i hadnt spotted before.....Ive only got 9 star type bolts holding cam cover down.......ones been replaced with a normal bolt  :o
Its the one far back on the right side.......where its leaking from.......im suspecting this is the reason  >:(
Bet the vx dealer doesnt have the correct bolt and i have to order one on tuesday  :(
Not convinced the bolt type would make a difference. Possibly hasn't been torqued properly (or its a bigger bolt coz some idiot has stripped the thread?
Chopsdad
Good on ya TD - I bet you feel better for doing it  ;)
Taxi_Driver
I was just wondering if the 'o' ring is still in place.....and yes certainly wouldnt have been torqued correctly......btw is there an order to tightening the bolts?
Taxi_Driver
QuoteGood on ya TD - I bet you feel better for doing it  ;)
Oh yes, my kitchen has a lovely smell of carb cleaner  ::)
Best not have a fag in their then ;)
Auto Addict
....the kitchen..... ::) ::) ::) ::)
I like red cars
Taxi_Driver
I did actually....str8 after finishing cleaning the pipes.....as AA said it was ok to take a ciggie break  ;D
Taxi_Driver
Thats whats the kitchen sink for isnt it...... ;D
Auto Addict
You try telling my wife that...... :o
I like red cars
Auto Addict
I like red cars
Markjay
I just go ahead and use the kitchen and living room whichever way I like i.e. for clueing, painting, or just otherwise stripping car parts (when my wife is away on holiday in another country that is...)
Alas, no more Omegas....
Taxi_Driver
QuoteGlad you've done it OK :y
Cheers AA  :y
Was thinking of having a go at the throttle body at some point.....after the cam gasket of course....as its looking a bit oily around the base of it......but couldnt even see that electrical connector in your how to.....mind you its a bit tight around it with the lpg injectors getting in the way  :-/
