Misfire?
Started by Bo Bo, 02 January 2007, 18:11:31
Bo Bo
Did a 330 mile round trip at the weekend & drove to work this morning with no probs. Half way home this evening I put my foot down & got what felt like a misfire (like it was running on five). I let off the power & all was fine again. It doesn't happen on gentle acceleration or if I rev it in neutral & there's no EML, I'm sure I've read similar on here but can't find it right now, any ideas?
HT problem I suspect.
Check for oil in plug wells (you know what that means), failing that, leads or DIS...
Bo Bo
I was thinking along those lines, I do have a slight leak on the drivers side rocker  :( but it hardly uses any oil.
QuoteI was thinking along those lines, I do have a slight leak on the drivers side rocker  :( but it hardly uses any oil.
Check the wells - drivers side is really easy to check. Resolve the oil problem before you kill a set of expensive leads....
Thats exactly what it sounds like to me.......
Bo Bo
Cheers, one thing I forgot to add; if I keep the revs up while this happens it clears again & roars away.
Anyone fancy bacon butties?  :D
QuoteAnyone fancy bacon butties?  :D
I can thoroughly recommend Bo Bo's Mum's bacon rolls :y
Did someone mention free food?  ;D
Blimey, you checked them plug leads quickly for oil.........
I wouldn't mind a trip to Coventry but I had better remove the LUFC sticker before I set off ;D
QuoteI wouldn't mind a trip to Coventry but I had better remove the LUFC sticker before I set off ;D
get an oof one instead ;)
Bo Bo
#11
QuoteBlimey, you checked them plug leads quickly for oil.........
I haven't checked them yet! I'll do it tomorrow if it ain't raining (otherwise it'll have to wait til Sat) but the rocket gaskets will need doing.
Bo Bo
Especially with all the MUFC ones around here  ::)
Oh I can do better than that, ive got two :)
Bo Bo
Quick update;
I've noticed that the misfire seems to be worse when the car's warm.
This morning it wasn't there (except once) on my way to work & I nailed it whenever I could to test it.
