lambda still....
Started by tyreburner, 09 January 2007, 20:07:27
tyreburner
bloomin thing
now only code i got is :
13 Oxygen sensor No change in voltage/open circuit.
any advice please on  what this means/where to look
cheers in advance
mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
Is the light still coming on?
Tina
I took a the meega out earlier & the light did come on, not instantly tho.
Mick is in bed now as up at 4am for work, but i will leave him a note on the bench.
My beast will be back with me soon :)
Quattro & Ummpphh what more can a girl want
Was the sensor replaced, of did he clean up the connections?
Tina
Aye he did replace the sensor & presume also cleaned the connections.
Which one did he replace because 13 is the drivers side one.....
QuoteAye he did replace the sensor & presume also cleaned the connections.
I guess he is going to spend the weekend checking the wiring between sensor and ecu then....
Tina
QuoteWhich one did he replace because 13 is the drivers side one.....
Im not sure, i will get him to answer this.
Tina
probably, and i want me 6x9s done  :(
but also want the meega put right, as i like the car lots
I'll look through TIS when I get chance (been a bit hectic here tonight with the Rover breaking down) - tends to give a step by step guide of simple things to measure, then suggests what needs changing (if anything).  Its not perfect, and is meant as a guide, not gospel...
Tina
QuoteI'll look through TIS when I get chance (been a bit hectic here tonight with the Rover breaking down) - tends to give a step by step guide of simple things to measure, then suggests what needs changing (if anything).  Its not perfect, and is meant as a guide, not gospel...
thanks,  i think he needs the meega sorted, and the quicker its sorted,
its chip done.
Then its play time
(fao:mick,  i wont redline it honest  ::)  )
Tina
QuoteWas the sensor replaced, of did he clean up the connections?
i replaced the passenger one
bugger so your advice to look out for a drivers one came true sooner than i wanted lol
tyreburner
ok this is getting bloody confusing now firstly i posted this but selfish witch decided to log herself in for keeps >:( so i posted it as tina
next light on and off this morning but on the way home nothing, i tried my damnest to get light on but nothing.... even though it was daylight i had every electrical thing on encase it was that , only difference was it was dry so i may get some heatshrink and try re connecting drivers one as  its crimped on with bullet thingys and wrapped in black and nasty? unless there is another reason the atmospheric conditions could have caused this???
