Found Bulb Missing Grrrr
Started by Craig_R, 12 January 2007, 16:24:31
Craig_R
Decided to change my Instrument Panel bulb today as the warning light sign of an engine has never been lit so i thought better get a new one for it, took the panel off to check the bulb and it did not have one, someone has removed it in the Past Thats very sneeky.
Anyway Checked the bulb for the sign with the little spanner popping out of the car and that bulb is fine but the light does not come on when i first start the car.
So i now have an orange engine sign on my Dash now all the time I have paper Clip tested it and it came up with
16  Knock sensor signal circuit  (Ill take it was because the engine was not running)
90  ?
0130 Heated Exhaust Gas Oxygen (HEGO) sensor ( would this have anything to do with my car running on LPG)
The engine was not running with the test as it did not seem to work with the engine running.
I think I read these codes right but ill double check tommorow in the light
Can anyone shed some light on what the codes mean please
Craig
Mod's
[To be Fitted]Reverse Sensors
Craig_R
#1
right i dont know if i am doing this right but i short out pins 4&6 turn the key and i get or i think i am
1690 MIL/Engine fail (malfunction indicator lamp) is this because i have not reconnected the MID or is it maybe the warning symbol of the car and spanner never lights ?
0110 Intake Air Temperature Sesnor (ATS)
0135 Heated Exhaust Gas Oxygen (HEGO) sensor heater
I might see if i can get a video camera to record this as i think its wrong as there is no 12 at the start it just gos
1690
0130
0130
0110
0135
1690
0130
0130
0110
0135
and so forth  repeating itself
Can anyone give me alittle advise please
Craig
Mod's
Taxi_Driver
The 1690 will be cause someone nicked the bulb!
And sounds like you have a lambda sensor fault......tho im sure someone else will be able to advise more on this
hth
Something not right - you should get a 12 to signify start of sequence...
Craig_R
#4
i dont know then but i get after turning the key   1 flash 6 flashes 9 flashes 10 flashes pause 10 flashes 1 flash 3 flashes 10 flashes
pause all the way through no 3 times repeating
also i thought i should only be getting 2 sets of flashes for the Siemens Simtec 56.0/56.1 ecu not 4 set like for the Siemens Simtec 56.5 ECU
i know mine is a W reg so it would of been late 2000 if that makes any difference
ill try and do the reset thingy of turning the key on 30 odd times you dont need the engine to start do you ?
Craig
Mod's
Quoteyou dont need the engine to start do you ?
Craig
yes, and run for a while...
Craig_R
or i could i just diconnect the battery or will that not clear the stored codes
saying that if i diconnect the battery my alarm will go off
Craig
Mod's
STMO123
Not if you disconnect it within 15 seconds of turning the ignition off
Auto Addict
Undo the terminal on the battery, but do not remove.
Switch ignition on then off, you have 15 secs then to remove the terminal before the alarm goes off.
I like red cars
but it wont clear the codes...
Craig_R
Thanks ill not bother diconnecting the battery
Found out that i have Siemens Simtec 56.5 ECU in my car i think so it does not have a code 12 only 4 digit codes thats why i am not getting code 12 at all.
I just want to double doule check this the engine management light  is the orange one that looks like an engine and in the hand book is called Exhaust Emission this is the one that should be flashing the codes up YES ?
Craig
Mod's
Taxi_Driver
QuoteThanks ill not bother diconnecting the battery
Craig
On prefacelift the engine symbol is the EML on facelift its the exhaust emissions.
Nobody spotted the obvious here then......
Concentrate on code 0110 - Intake Air Temp Sensor, this will cause a richer mixture and associated lambda control faults......
Craig_R
Thanks Mark
Where is the Intake Air Temp Sensor Live ?
is this it here ?
Craig
Mod's
I believe thats it, thats where v6 one is...
