vacuum pipe (help)
Started by mike9570, 23 January 2007, 15:43:40
mike9570
:question after giving the omega a full service i noticed a small black vacuum pipe just hanging loose ( see pic),had a good look around but cant find anything it might go on,  there is a small plastic piece stuck in it and it looks like its snapped off. could this have something to do with the heaters direction..   :question
thanks  mike
sorry forgot to mention is a 94 2.0l cd auto ...if thats any help
thanks again u
What is the other end attached to (this should give us an idea if its connected to a vac source or actuator)
mike9570
1 min ,just go take a pic .
mike9570
the 1 with green line on , bud
Ok....I suspect it should connect to the barke servo vaccum line (bloody big pipe with a one way valve in it) near the one way valve....it might have been snapped of from here....
It lookslike the vac feed to the reservoir above the pollen filter which does indeed conrol the heater etc....
Do you also have a pic of the brake servo pipe near the one way valve....
mike9570
Yes...a lot.
Can you see just to the right of the branch on which another vac pipe is attched there is rough section....looks like the pipe has broken off here..........worth a closer look to see if its been buggered with in the past or just happened (look for signs of glue)
mike9570
is this the right place,  someone put a screw where it snapped off..
Looks like some kind person has put a screw in the hole......
Was the heating direction etc working?
mike9570
only works on windscreen ..
mike9570
cheers mate , great help thanks , ill go and sort it and get warm feet hopefully  :y :)
Chopsdad
Quotecheers mate , great help thanks , ill go and sort it and get warm feet hopefully  :y :)
Just make sure they are not warm wet feet - got to wonder why screw used to replace hose in the first place :-?
Right, what has happend is that the plastic stub has broken off the servo pipe...this is causing the heater trouble.
You have two choices.
1) Put a T-piece on the remaining tap point to to ffed both vac pipes.
2) Remove the screw from the servo pipe and the broken piece of pipe from the vac tube end. Flatten the end of the broken section of pipe and find a drill bit which is the same diameter. Use the drill bit to open out the hole in the brake servo pipe. Then roughen the area around drilled hole. Place some super glue around the outer end of the broken piece and insert it 2-3mm into the hole, apply more glue around the outer piece to re-enforce the joint (epoxy is actualy better for this bit) Leave to dry and re-attach the vac pipe as it should be.
3) Get a replacement servo pipe from a scrapper.
mike9570
what i was thinking off is drilling out a brass screw and screwing back into the hole then fit the pipe back on
What ever you are most comfortable with.....just dont screw it in to far and restrict the vaccum to the brake servo..
