me lambda again... sorry
Started by tyreburner, 24 January 2007, 16:22:47
tyreburner
Hi today i had a look at drivers lambda and found this:
so think i know why its throwing the open circuit code lol
But should lambda sensors rattle???
Think i will be buying another one  ;D
Mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
Thats the heater wire....not the sensor.........no, they shouldn't rattle....check the other connections and if you can, replace the crimps with a soldered and sleeved connection.
tyreburner
#2
QuoteThats the heater wire....not the sensor.........no, they shouldn't rattle....check the other connections and if you can, replace the crimps with a soldered and sleeved connection.
have soldered and heat shrunk em all cause i am getting code 13 which iirc you told me was the drivers one mark? as the passenger one was replaced  :y
gonna get another one though as not happy, she did 40 mile yesterday and range hardly dropped i drove back home and used 60 miles of range although she drove harder than i.. only difference being i got the eml on  >:(
but its deffo paggered as it rattles like a bit china inside of it
