Author Topic: Key - All Doshed In !  (Read 2941 times)
Scotty
  • Manchester
« on: 28 January 2007, 09:48:27 »
How Do Everyone,
Just picked up my 3rd Omega ( 2.2 Auto CD ) yesterday. Well pleased with it.
However, the key is all doshed in where you press to open/close etc.
How does one go about obtaining a new key? Thats presuming you can.
How much are we looking at?
Cheers
Andy
Admin
Re: Key - All Doshed In !
« Reply #1 on: 28 January 2007, 10:04:11 »
Hi and welcome Andy. :)
This is quite easy. What you need is something like this: http://cgi.ebay.co.uk/Vauxhall-Omega-Vectra-Astra-Remote-Key-Fob-3-Button_W0QQitemZ230083718457QQihZ013QQcategoryZ10404QQrdZ1QQcmdZViewItem
 (depending on whether you have 2 or 3 button model).
Just use that as a donor. The main body comes apart from the key.You just need the casing.
Open the main body (carefully). Swap over casing and you are done. :)
« Last Edit: 28 January 2007, 10:07:55 by admin »
The Administrator.
Scotty
  • Manchester
« Reply #2 on: 28 January 2007, 10:13:59 »
Thanks for the reply, much appreciated.
Is there another way other than ebay? Any independant dealer services
or web sites??
Andy
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #3 on: 28 January 2007, 10:16:21 »
or web sites??
Andy
Why  :question  I would think only other source for new fobs would be Vx
« Reply #4 on: 28 January 2007, 10:43:18 »
A replacement fob would mean programming to car via Tech2. So, not only do you have fob costs, but Tech2 charges, and buying a carpass if you do not own one...
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #5 on: 28 January 2007, 11:24:59 »
Last time I checked at Vx, they will now only supply the modern type which has the flip-out key blade. So supply and coding of that works out to about £100, as opposed to a replacement casing which would probably cost £10-15 tops ...
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 28 January 2007, 14:39:20 »
Nip to your local scrappy, show them your key, explain that you only need the casing,  a few beers me thinks!
That's what I did !
Regards Arthur Daily & Ocassionally Fortnightly
Markjay
  • London
« Reply #7 on: 28 January 2007, 16:30:25 »
When I got my spare key from VX (some time ago now), it was around £80 (programmed and ready to go) which was made up from ~£35 for the fob and ~£45 for the key itself. The new 'integrated' fob is still actually separate to the key - it simply slides onto it...  so at the time they could be bought separately even if it was the 'new' type.
Alas, no more Omegas....
bigall
  • merseyside
« Reply #8 on: 28 January 2007, 18:22:57 »
I used North West Key services in Liverpool.
Supplied a new three button fob and programed it to my car took about 10 minutes
Cost £45.    Needed the "carpass" for programming
Must be something similar were you are          try Yellow Pages for auto locksmiths
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Scotty
  • Manchester
« Reply #9 on: 29 January 2007, 08:29:45 »
Thanks for all the replies.
I think I shall try the scrap yards first.
Cheers
Scotty
