V6 stalling/poor running
Started by stuvaux, 19 January 2007, 08:48:54
stuvaux
ok thanks
could the seal around the IAC valve cause a leak?
it doesn't seem to fit as well as before i removed it
Take a look at my Dog Training blog at Dog Training HQ
stuvaux
ok,  i've oiled the IAC valve - drove the car, problem seemed fine - but now it is back again!
when the car starts to run badly, at tickover, the instant consumption is at 0.8 gal/hr, where it is normally only about 0.3 gal/hr
also, there is a strong smell of bad eggs(!), which i know is the cat
any ideas?
thanks,  stu
stuvaux
could this mean one of the cats is knackered?
or could it be excess fuelling causing the smell?
any help on what to check next woulb be appreciated
thanks
stuvaux
still no joy!
not really sure what to look at now
someone said it might be a blockage in the exhaust?
stuvaux
please help....
any ideas would be very much appreciated!
i want my miggy back!
thanks,  stu   :-?
Markjay
#20
...have you checked for any stored fault codes?
Alas, no more Omegas....
stuvaux
i haven't yet
as there was no EML, i didn't think the ecu had picked up a fault
i will try anyway...
thanks
stuvaux
there are 2 codes coming up -
19 & 135
according to my code list, this is RPM signal (crankshaft sensor) - incorrect signal & `Check engine` lamp - low voltage
does this mean its likely to be the crankshaft sensor?
19 = knackered cranksensor  (31 is normal crank sensor fault when engine not running)
stuvaux
so definitely a knackered crank sensor then?
where is the best place to get one of these from
autovaux quote £28.17 for the oval type, and £46.83 for the square type
which is the most likely one for mine, a 1999 2.5V6
also, what does the 135 code mean?
thanks
rpont
The 135 code was posted a bit above, EML light. I've got a 135 but I disconnect the battery with the ignition on and I bet that's where I got it from.
I think the oval one is the latter type, I also need one. I think the square type also needs a new seal. I'm hoping that by removing the scuttle I'll be able to see what type of plug it is.
stuvaux
thanks mate
according to the haynes manual, you should be able to see the connector once the scuttle is off
stuvaux
fitted new crank sensor yesterday
car was running fine until today
the stalling problem has started again
it is still showing fault codes 19 & 135
can anyone suggest where i should look next???!
thanks,   stu   :o
stuvaux
fitted a working IAC valve today
worked fine for a bit
problem is now back again!!
really not sure what to check next now - HELP!!!!!!
stu   :(
Sorry I have not replied before......
Can you try something.....when it idles badly, can you give the EGR a clonk with a hammer on the metal body.....
