V6 stalling/poor running
Started by stuvaux, 19 January 2007, 08:48:54
stuvaux
hello guys
this problem started two days ago and is now getting worse
at first the car started to run badly at idle speed
then the problem went as quickly as it had appeared
then it came back again!  when it happens, sometimes it stalls. then i restart it. it stalls....restart....stalls....
also, it seems there is a lack of power as you pull away. the revs take a while to pick up, then it seems flat for a bit, under 3000 revs
any ideas on where to start looking would be very much appreciated!
thanks,   stu
Take a look at my Dog Training blog at Dog Training HQ
Any EML, if not, does EML come on with ignition?
stuvaux
no EML, but light does come on with ignition, and go off as normal
i'm sorry about the explanation of the problem - its just a tricky one to put into words!!
i did clean the IAC valve the other day - it was fine for two days after that - then the problem started - could that be related?
thanks,   stu
Quoteno EML, but light does come on with ignition, and go off as normal
thanks,   stu
How did you clean (carb cleaner)?  Did you oil afterwards?
The power loss could be related to multirams, check they work properly as well...
stuvaux
yes, cleaned with carb cleaner, but didn't oil afterwards - should i have, and what with/how?
how do i check the multiram is working properly?
stu
Quoteyes, cleaned with carb cleaner, but didn't oil afterwards - should i have, and what with/how?
stu
A light oil, 3-in-1 etc...
When it stalls, is it a sudden stall, or does the engine hunt a bit?
stuvaux
yes, engine hunts for a while, then stalls if i dont,t rev/pull away
stuvaux
is wd40 any good on the IAC valve?
dont think i've got any 3 in 1 oil
Auto Addict
Quoteis wd40 any good on the IAC valve?
WD40 is not a true lubricant.
I like red cars
bestseany
Is your problem happening when you're running on petrol or LPG?
stuvaux
its happening with both fuels
Not really. A light oil is what you are after, and just 2 or 3 drops...
stuvaux
ok   i'll try that
how about the multiram?   whats the best way to check if it is working as it should be?
thanks
The multiram won't cause stalling, but will affect power at different rpm.  Fix the stalling issue first...
Also, air intake leak may also give stalling/uneven idle symptoms...
