Author Topic: alarm  (Read 2586 times)
mick-1975
  • nottingham
alarm
« on: 31 January 2007, 18:49:19 »
    any idea to stop the alarm from keep going off
       replace battery in key fob and had main battery
tested ok
     mick >:( >:(
Re: alarm
« Reply #1 on: 31 January 2007, 19:21:59 »
nicads in power sounder....
Markjay
  • London
Re: alarm
« Reply #2 on: 31 January 2007, 19:39:04 »
Yes, and also, if you sometimes hear four faint beeps from the engine compartment then it is definitely the NiCd batteries in the sounder that need replacing.
Other than that check all the door switches and mainly the under-bonnet switch - if it is too short it may trigger the alarm.
Alas, no more Omegas....
mick-1975
  • nottingham
Re: alarm
« Reply #3 on: 31 January 2007, 20:08:33 »
thanks
   what sort of batteries does it take without taking it off
when first got car nothing happened this has just recently
started....
     ive had 2 disconnect the battery tonight as im at work at 4 and dont want to wake neighbours
   wont be happy    mick
« Last Edit: 31 January 2007, 20:13:52 by mick-1975 »
Re: alarm
« Reply #4 on: 31 January 2007, 21:24:21 »
The are specialist batteries, perhaps someone can dig out the supplier.
If anyone near you has a Tech2 (not sure if cheapo one can read alarm codes) that can tell you why its gone off...
Markjay
  • London
Re: alarm
« Reply #6 on: 31 January 2007, 23:09:28 »
You can get them here;
http://www.cellpacksolutions.com/Search_All.asp?searchall=z3a120&Submit4=Go
You will need 2 of these:
« Last Edit: 31 January 2007, 23:10:15 by markjay »
mick-1975
  • nottingham
Re: alarm
« Reply #7 on: 01 February 2007, 16:36:42 »
   ;Dthanks i shall disconnect the power sounder and
wiring tonight to get the neighbours off my back
      i shall have to try and get a another one from somewhere
  any advice
mick :y :y
Page created in 0.008 seconds with 16 queries.
