Veccy Paperclip Test
Started by Timbuk, 01 February 2007, 14:55:46
Timbuk
Has anyone ever papercliped a Veccy before with success? Pops has got a 97 2.0 CDX, all the veccy sites are saying pins 5 & 6 but it's just not working :-/
nixoro
QuoteHas anyone ever papercliped a Veccy before with success? Pops has got a 97 2.0 CDX, all the veccy sites are saying pins 5 & 6 but it's just not working :-/
Is this with the engine running or with the key turned to have dashlights showing?
My 2.0 flashes the codes without the engine running as above maybe worth ago.
4 or 5 and 6.....4 and 5 in theory are both 0V
Timbuk
Tried it both ways :(
nixoro
Is it a 16pn aldl connector?
Supposedly the vectra has a simtec 56.5 same as mine so in principle should flash the codes the same way.
Timbuk
QuoteIs it a 16pn aldl connector?
Now your getting technical :o  Its exactly the same as my meega, down to the positioning of every pin and every blank :-?
Tried it with the engine running?
Is it the later X18XE1 engine with drive by wire throttle?
Timbuk
QuoteTried it with the engine running?
Yup, tried it with engine running and ignition only, drive by wire ... er i dunno... 97 car wouldn't have thought so. Link 5 & 6 and the eml goes off and thats it :-/
Its just possible, the Vectra went drive by wire quite early on with the 1.8 (Think it was actualy late 98 thouhg).....is there a throttle cable?
I assume the ECU bulb is working ok.....
What are the fault symptoms...?
Timbuk
QuoteIts just possible, the Vectra went drive by wire quite early on with the 1.8 (Think it was actualy late 98 thouhg).....is there a throttle cable?
Dunno about cable, i'll ask him later. It was cutting out when slowing down which i think was the icv, cleaned it out along with the breathers and it seems ok now, but just wanted to know why it wouldn't paperclip
It should work........
Did you also clean the throttle body and fit a flame trap to the front right breather elbow?
Timbuk
QuoteIt should work........
Flame trap ........ No
Veccy and flames  ;D - Sounds like a good idea!
Sorry can't offer any helpful advice Tim!
I've paperclipped a 2.5 v6 veccy-b a while back, does eaxctly same as Omega. Never tried a smaller Veccy, as I have the proper gadget...
Admin
QuoteI've paperclipped a 2.5 v6 veccy-b a while back, does eaxctly same as Omega. Never tried a smaller Veccy, as I have the proper gadget...
Show off!!  ;D
The Administrator.
