Author Topic: alarm again soz  (Read 1598 times)
mick-1975
  • nottingham
alarm again soz
« on: 02 February 2007, 16:53:42 »
        disconnected the power sounder and wires and still
  the lights flash instead off the alarm going off neighbours releived
  can i disconnect the whole alarm until i find a replacement
    thanks  mick
Re: alarm again soz
« Reply #1 on: 02 February 2007, 18:07:57 »
No.
Find out whats setting it off then.  Likely candidates are bonnet switch (though tends to be more in hot weather) or ultrasonics (your manual tells you how to disable every time you leave car)...
Admin
Re: alarm again soz
« Reply #2 on: 02 February 2007, 22:02:59 »
As TheBoy said, the bonnet sensor is a common culprit.
Easy to confirm. Simply lift bonnet, reach to back and firmly tape down sensor Easy to spot....
If alarm stops going off, great.
If not, when you get out the car, press the little button above the headunit with a picture of a man running away. This disables the interior sensors (for when you have kids/dogs in a locked car).
The Administrator.
ste
  • West Yorkshire
Re: alarm again soz
« Reply #3 on: 03 February 2007, 17:56:30 »
Hi,  Don't know if this will help you, but I had a problem with my alarm going of when it felt like it.  kind of pissed the neighbours off a bit so I investigated.  Checked bonnet swith and that seemed ok, so after I had scratched my head a bit and smoked half a dozen fags, I started messing about with the sounders.  I discovered that the power sounder that looks like a horn was quite basic and not likely to cause the alarm to go off.  After a bit of research I learned about the auxilary sounder that is suppost to have it's own backup power supply for if the battery is disconected.  This seemed to not work correctly so I have unplugged both sounders and now the alarm doesn't go off when it feels like it.  I haven't yet got round to reconnecting the main sounder but i'm quite sure that when I do, there will be no problem.  Also need to get a new auxilary sounder.  I think it was this that was triggering the alarm.  Soory for been a bit long winded but hope the info helps.
mick-1975
  • nottingham
Re: alarm again soz
« Reply #4 on: 05 February 2007, 17:06:27 »
 :y many thanks for the reply had another look
today at the bonnet sensor moved it a little
seems to be ok  has not gone off yet
      hope thats it  sleep at last
 mick
