Misfire when warm?
Started by colalowe, 13 January 2007, 09:53:39
colalowe
Hi all, My Omega has started to develop a misfire once its warm, from cold she drives fine.
She also had a full service at vauxhall about 6month ago and I had to change the plug leads due to a mis fire then but this sounds and feels different as it only seems to do it under load and once its warm!
Any Ideas?? :-[
Any EML coming on?
Any oil in plug wells?
Has DIS been changed?
colalowe
No there are no lights comming on and no oil, I havent changed the Dis yet as it runs fine when cold, it may be my next option though.
Craig_R
I Think The Boy is askng about the dissy pack as problems can start once the pack has gotten hot causing misfires
Craig
Mod's
[To be Fitted]Reverse Sensors
Missing under load with no EML frequently points towards HT issues. Given that leads have been changed, that leaves plugs and DIS. Or oil in plug wells....
colalowe
Thanks for the ideas,
im going to check for oil in the plugs first, is there any way of checking an HT lead or is it a case of just having to buy a new set and see??
colalowe
I think ill just buy a DIS unit and replace that anyway as plugs and leads have been changed in the last 6 months, id be surprised if they have failed already.
The DIS is expensive (as are leads), so rule out other possibilities first.  The leads do not take kindly to hot oil, so leaking cam covers will ruin them. Oil in plug wells also will cause miss, and is again a sign of leaking cam covers.
colalowe
#8
Cheers for that 'The Boy' I will definately check the wells for oil first as I know there is a slight leek from one of the cam covers so this may be the problem!
QuoteCheers for that 'The Boy' I will definately check the wells for oil first as I know there is a slight leek from one of the cam covers so this may be the problem!
Ahhh, change the cam cover gaskets (use genuine Vx, and BLACK sealant).
Empty the plug wells of oil (syringe, or kitchen roll) asap, as cats don't like misfires, and plugs/leads do not like being baked in oil...
colalowe
Today I had a look at the  plugs and sure enough plug No 3 was full of oil! Ive cleaned it out but the car still misfires, :(
How much will it cost to have the cam cover gaskets replaced and is it worth having the head gaskts replaced at the same time?? :-/
QuoteToday I had a look at the  plugs and sure enough plug No 3 was full of oil! Ive cleaned it out but the car still misfires, :(
To change the gaskets, see the guide in Maintenece Guides section. And clean the breathers!
Matchless
You can check HT leads for broken connections using a multimeter on resistance. Measured resistance is proportional to length so its easy to spot one which is high resistance for its length or a broken one.
When the leads have been sat in oil the rubber seems to lose its insulating properties and the HT leaks to earth. Cant test for this except by substitution.
If it was a DIS pack breaking down then you would expect two cylinders to be misfiring, not one.
Admin
Cam cover gaskets are not too bad to replace. Probably about 3-4 hours the first time.
If taking to a garage ( :-/) make sure they know what 8nm is!! This is the torque setting of the cam covers. Tighten much more than this and you crush the gaskets causing leaks... again!
Also, as said before. The breather system MUST be cleaned thoroughly as the blockages in this cause the leakage.
As for changing head gaskets?  :o
Err, I really would not recommend it unless you feel you have far too much money and wish to dispose of a large sum of it for no good reason! ;)
Nothing wrong with the heads by the sound of it.
You may well need a replacement DIS pack though... (approx £80 off ebay, more from dealer!)
The Administrator.
colalowe
Thanks to all the advice Ive had here so far,
the day after cleaning thoil out from the plug well she ran fine again and is still running fine now,
I get paid next week so first chance I get I will be changing the cam cover gaskets and cleaning the breather system, so fingers crossed that will sort the problem permenantly.
Cheers once again and Ill let you all know how I get on, (probably be back asking about how to get something of first no doubt!!) ;D
