Upgraded to MID - it works - Sort of!
Started by JamesV6CDX, 15 February 2007, 19:39:46
Fitted MID to the 2.0 GLS today. It works, but need to sort out some errors.
It's displaying:
Coolant level
Oil lack
Brake Pad
Washer Fluid Level
Headlight / Tail light
Presume I just need to fit some sensors to cure these? Such as replace the coolant and washer bottles for ones with sensors? Will the loom connectors already be in place for these? What about the oil lack, and brake pad sensors?
Also, the headlight/tail light one, where does the MID communicate with this?
Any advice would be ace, because if I can sort this, I have a working MID in the GLS!!
coolant level, should be easy... just new header tank.
Oil lack, could be tricky not sure how it reads that?  :-/
Brake Pad - Again easy, should just be sensors.
Washer fluid level, again should be ok, replacement sensor from scrappy. I am wondering if you might need a new washer fluid tank  :-/ Depends if you have a blanking slot for the sensor...
No idea on the headlights... sorry.
Btw James I have a spare brake sensor, its cracked but it works. We can test on Sunday, see if it removes the MID error  :y
Martin_1962
James - you must have these bits on the scrapper or the V6.
I'd check if you have rear windows as well - get them off before you scrap them
QuoteJames - you must have these bits on the scrapper or the V6.
Indeed... I plan to transfer the rear electrics over! also the CD changer too!
The Scrapper has a MID, so I'm sure that will have sensors...
I'm just not sure where they all are!
Does the fuel computer work on it (albeit inaccurate due to wrong config)
QuoteDoes the fuel computer work on it (albeit inaccurate due to wrong config)
It does, it's calculating Range, Inst Cons, Consumption and speed!!
Just need to iron out the sensor niggles, but I need to find out where they all are...
Coolant is in bottle, oil may be in sump, might be a pig. Pads may just need sensor. Lights will probably need the unit. And as to loom.....
Martin_1962
Well the prefacelift has two pad sensors.
header tank for level
Oil - I think it must be a sensor on the sump - worst case swap sumps
QuoteBad news then?
Lights, what unit?
don't forget I can steal it all off the scrapper...
what are the chances of all the plugs being on the loom?
If not, guess I'm screwed?
Martin_1962
Well James you may as well get EVERYTHING off that CD you can use, if you are trying to produce a 2.0 Elite you can't neglect a few sensors!!!!
Jaime can check the config on Sunday afternoon
QuoteWell James you may as well get EVERYTHING off that CD you can use, if you are trying to produce a 2.0 Elite you can't neglect a few sensors!!!!
Totally agree!
Anyone know the locations of the sensors though?
Coolant sensor is under the coolant bottle.
Washer level sensor is on washer bottle (obviously!)
Oil level sensor is on the sump pan
Brake pad wear sensors....fairly obvious....
Bulb check requires the check control module adding
Or, short the check signal pins to 0V on the back of the MID....
QuoteCoolant sensor is under the coolant bottle.
I think I'll fit the relevent sensors
Will the loom already have the connectors in place for the sensors?
Will the sump need changing?
Also, where is the bulb check module?
