Author Topic: Rear subframe mounting bushes ?  (Read 3796 times)
Glenn
  • Oxfordshire
« on: 16 February 2007, 09:10:36 »
Has anybody here ever changed the mounting bushes at the front of the rear subframe ?
Looks like my subframe occasionally moves far enough to touch the right hand silencer, about 1/2 inch forward.
Thanks
Re: Rear subframe mounting bushes ?
« Reply #1 on: 16 February 2007, 09:12:50 »
I think Omegatoy has from memory.....
Omegatoy
  • UK
« Reply #2 on: 16 February 2007, 19:10:43 »
yep easy job mate!!!
undo big bolt in middle undo 3 outer bolts use claw hammer edge to drag out the old bush and reverse mounting plate to push  new one in  do it right and half an hour each side no worries,
Omegatoy
Glenn
  • Oxfordshire
« Reply #3 on: 17 February 2007, 21:51:50 »
Thanks mate, that makes me feel much better about it.
Why did you have to change yours ? and did it make any difference ?
Cheers
« Reply #4 on: 17 February 2007, 21:57:20 »
iic big difference... he used plastic ones forget the brand.... aussie ones i think, vaux ones are rubber, cheaper than plastic but don't last as long
His comments were big difference and felt a lot stiffer at the back  :y
Glenn
  • Oxfordshire
« Reply #5 on: 17 February 2007, 22:39:50 »
Thanks Tunnie, interesting...... I'll have to have a scout round, see what I can find.
I used to work for Tom Walkinshaw, he's still involved with HSV, maybe I'll see if his guys can sort anything for me.
Omegatoy
  • UK
« Reply #6 on: 18 February 2007, 07:36:57 »
he should nbe able to get them then have the box here with the pary numbers etc if its any use to you!!
Omegatoy
JasonH
« Reply #7 on: 18 February 2007, 09:22:36 »
I'd be interested in part numbers and prices.
Anyone know much much genuine parts are?
Omegatoy, when you did yours did you simply remove the central bolt and 3 outer bolts then use the hammer or did you lower the subframe, exhaust etc.?
How did you jack the car, support the sub-frame etc?
I suspect one of my bushes is on the way out. I don't have a puller or a way of pushing the bush back in so I was considering taking it to a garage. If the bushes come out easily then I'd rather do it myself.
Omegatoy
  • UK
« Reply #8 on: 18 February 2007, 21:43:42 »
diy is easy mate, bit difficult to explain but once you have undone the bolts and removed the carrier plate you use a claw hammer in the three slots around the edge of the old bush these are metal so you can safely give it a good heave, I just jacked up the rear but if you have never done it before put the whole car up on axle stands and ramps so you can see exactly what your doing, you only need to lower the arm slightly to get the top hat bush piece ,(extra bit on top) outn and th enew one in you will see what i mean when you do it, if you cant get the new bush to seat fully home then you just revesrs the 3 bolt plate so its upside down and then bolt up the centre bolt this will push the bush fully home!!
should have done a piccy job really but i have done sos many its second nature!!!
Omegatoy
Glenn
  • Oxfordshire
« Reply #9 on: 18 February 2007, 22:01:02 »
Part number would be great, thanks
Omegatoy
  • UK
« Reply #10 on: 18 February 2007, 22:08:56 »
its in the garage can get it tomorrow or if you want you can come over and get the box so you have all the details including the manufacturer?
Glenn
  • Oxfordshire
« Reply #11 on: 19 February 2007, 08:32:34 »
Sounds good, where abouts are you ?
Omegatoy
  • UK
« Reply #12 on: 19 February 2007, 08:51:28 »
you have pm!!!
