no traction
Started by Mole, 19 February 2007, 18:07:16
Mole
i've got an ex police mv6 auto and it has traction control but no t/c button. i want to be able to turn off the traction control or disable it altogether. if i pull the abs fuse out the abs, t/c and the speedo stop working but this is not an ideal solution. will there be wiring hiding behind the dash for a t/c button as i can source on of these?
Quotei've got an ex police mv6 auto and it has traction control but no t/c button. i want to be able to turn off the traction control or disable it altogether. if i pull the abs fuse out the abs, t/c and the speedo stop working but this is not an ideal solution. will there be wiring hiding behind the dash for a t/c button as i can source on of these?
This might be of use to you.
