Throttle Cable
Started by ians, 20 February 2007, 17:55:55
ians
This is likely to be dim post of the day but here goes.
Trying to embark on the camcover gasket replacement procedure and got as far as removing the throttle cable (yes that far..).   Got the little paperclip thing off and expected the ball and socket to come apart (no mention of any trickery in any of the guides/Haynes etc) but the bugger won't come off.
I'm aware that I could leave it attached to the plenum but as a) as I want to give the plenum a good clean and b) I'm stubborn, I want to remove it.
Is this a brute force job (I'm concerned lest I damage the throttle mechanism or further damage the cable ball) or is there something I'm not aware of?  I've given it a soak in WD40 in blind hope but no joy.
Cheers
Ian
jonathanh
take the paperclip thing completely out  (slide it towards the rear of the car) then give the socket  a good wiggle.  Mine was stuck but eventually freed itself.  Strangely enough I think it is worse when it is cold.
STMO123
QuoteThis is likely to be dim post of the day but here goes.
Cheers
Ian
Please dont be afraid to ask ANYTHING on the forum Ian. You'd be surprised at how patient and understanding the people on here are :y
If the clip is out, you just need to force the ball out of socket...
sounds2k
there's a ball on the throttle, the end of the cable (spring) clips over this, the clip locks it in place - so remove the clip first - from memory on my old omega I think I used a pair of pliers to get it off initially ... the one on my current one is a bit looser and can be pulled off fairly easily ...
Auto Addict
Had that problem with my mates 2.0 estate, just wouldn't come out.
I like red cars
ians
Thanks all
The Boy -my eyes are watering but I think I get the message!
Cheers,
Ian
Craig_R
#7
LOL it had me fighting for ages with it to get mine off first time with the clip removed, second time i need to remove it i just could not get it off and it did my head in and i gave up.
Craig
Mod's
[To be Fitted]Reverse Sensors
ians
Well it still refuses to come off even after a night soaking in wd40 and some gentle warming, so I've given up for the moment.   Any more force and I think i'm likely to risk bending the cam mechanism or destroy the socket on the throttle cable - already doesn't look pretty.
Am I right that the throttle housing needs to come off the plenum for cleaning?  If so, at least I can get the plenum itself off the car.
Cheers,
Ian
QuoteWell it still refuses to come off even after a night soaking in wd40 and some gentle warming, so I've given up for the moment.   Any more force and I think i'm likely to risk bending the cam mechanism or destroy the socket on the throttle cable - already doesn't look pretty.
Cheers,
Ian
The throttle body needs to come off for proper cleaning
bestseany
Twist it lightly as you pull it too. Pulling at an angle might help too.
Be careful not to damage it like I did though. I damaged the edge where one of the holes are for the clip. I had to shorten the clip down in the end to get it to fit.
Quote....
I did that too the other day, when my throttle cable wouldn't come off the ball. I had a 1mm drill though to open out the hole a little.
ians
Hmm - suspect I have managed that too - and still the b'stad isn't off.  I have tried rotating the socket, different angles etc  although I'm also concerned about damaging the throttle cable (don't need yet another job)
