Author Topic: coolant loss????  (Read 5760 times)
infinity1
  • sunny south east
coolant loss????
« on: 04 February 2007, 21:46:44 »
evening chaps,little bit of advice please...this afternoon while taking the family out,the displays chirps up a coolant low message..upon getting home it was indeed low,so i 50/50 and filled it up again,approx 1-pint(ish).now this is all ok ,just that approx 4 weeks ago ,coolant low message was on the display ,and again i filled it up, yep you guessed it approx a pint,so in about 4/5 weeks and roughly 650 750 miles it has used 2 pints of coolant,now, the acid question is this fairly normal(cough!) or should i be starting to worry about something?no gunk in the header tank,no gunge around the oild filler cap etc,and as far as im aware no leaking hoses etc.anyone got a rough idea of what it could be?
oh yes i havent done a coolant flush yet,could that be a prob?
mechanics? not me at all mate...
Re: coolant loss????
« Reply #1 on: 04 February 2007, 21:51:19 »
Check the heater bypass valve at the back of the engine
reglar culprit..
Markjay
  • London
« Reply #2 on: 04 February 2007, 21:51:27 »
Check HBV at back of engine.
If no visible leak anywhere, you may have the usual oil-cooler problem...
Alas, no more Omegas....
Markjay
  • London
« Reply #3 on: 04 February 2007, 21:52:12 »
JamesV6CDX you'r fast mate...  ;D
« Last Edit: 04 February 2007, 21:52:23 by markjay »
« Reply #4 on: 04 February 2007, 22:02:45 »
as said, check hbv first...  ...then move on to coolant bridge....
infinity1
  • sunny south east
« Reply #5 on: 04 February 2007, 22:07:32 »
fingers crossed its the hbv....so my next question any guides to changing this please..?????
Markjay
  • London
« Reply #6 on: 05 February 2007, 00:07:30 »
I claim no credit for this picture, it has been widely used on this forum as well as on the other, the HBV is item C:
« Reply #7 on: 05 February 2007, 03:01:38 »
Story of my life  ;)
infinity1
  • sunny south east
« Reply #8 on: 05 February 2007, 12:00:59 »
markjay your a gent,cheers,
bestseany
  • Flintshire, North Wales
« Reply #9 on: 05 February 2007, 12:16:46 »
I have to top my coolant up every two weeks or so, although I don't have any visible leaks either. I checked my HBV when I did the rocker gaskets and that was fine.
However, I have noticed some crystals on the front of the radiator even though it's never looks damp, so i suspect it may be a slow leak from that. Worth remembering to check that too.
    • E250 Est / Elroq
« Reply #10 on: 05 February 2007, 12:29:51 »
Must be the season for it!
Im getting through abou 1 litre every 200 or so miles
HBV was damp, so I replaced it, easy, but fiddly, the trick is to find a good way to remove the bloody clips!
I needed to do a coolant flush, least this has done it for me!
Gawd knows where its going, cant find anywhere else damp
No oil in water or vice versa.
Maybe we need a coolant loss party!
bestseany
« Reply #11 on: 05 February 2007, 12:35:59 »
What's your radiator like? I took the plastic cover off the top and looked down the middle between the radiator and the air con radiator - it doesn't look damp but there's white crystals building at the side of it.
    • E250 Est / Elroq
« Reply #12 on: 05 February 2007, 12:44:30 »
Dunno tbh, will have a look when I get a chance, time isnt on my side at the moment unfortunately.
Essex_Andy
  • Have a guess?
« Reply #13 on: 05 February 2007, 21:57:29 »
'usually' if you have an external leak of coolant you can smell it.....sickly sweet smell
I sincerely hope its not an oil cooler cover erroding like I had.
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
bestseany
« Reply #14 on: 06 February 2007, 11:35:30 »
I had a leak of gas that had a very sickly sweet smell a few months back, but that was the air con gas.
