coolant loss????
Started by infinity1, 04 February 2007, 21:46:44
Arrolman
Hi all,
I picked my 1997 2.5 CD Omega up on Fri but didn't use it over the weekend due too work, only been using it daily since Mon and im having to top up my coolant header every 100 miles, no visible signs of leaks. It may be the valve as stated in this post, but how do you access it? That engine looks like its showing you it on the back which isn't accesible from under the hood
Daft question?!?
Cheers,
Iain
Looking to win the lottery..........
QuoteHi all,
Daft question?!?
Cheers,
Iain
Hi Ian and welcome to the forum
Try this http://www.omegaowners.com/forum/YaBB.pl?num=1152710108
This should give you a bit more room at the rear of the engine :y
Arrolman
Excellent,
Will give it a go when the rain goes off.
Cheers,
Iain
Chopsdad
Is it contagious? :(  Whenever I read of a new problem on here my Megga catches it  >:(
Just checked my coolant level and its about half an inch below min  >:(  No oil on top of water and both dipstick and filler cap are clear.  I'll check for leaks at the weekend.  :-/
