Towing Electrics
Started by Pitchfork, 28 February 2007, 20:11:02
Pitchfork
I would like to fit a towbar to the tractor
Is the wiring already there, if so where can I find it?
Are there any other things that are needed e.g. additional relays etc?
Ian
QuoteI would like to fit a towbar to the tractor
Ian
Yes, behind plastic trim in boot...  ...iirc, another relay reqd...
Pitchfork
Thanks, it's an Estate - does that make any difference to where the connectors are?
Can anyone tell me what additional relay is required & where it goes?
QuoteThanks, it's an Estate - does that make any difference to where the connectors are?
Have a look here clicky
