programming I.R fobs
Started by OMEGA VXR, 27 February 2007, 14:13:33
OMEGA VXR
Hi all
Ive bought 3 Infa Red fobs for my 1994 omega (chunky fob with 2 buttons)they are used fobs from flebay with new batteries and i was wondering how you programme them do they need tech 1 or 2?
Could any of you guys be able to do it for me,cos pretty sure VX are gonna want a small fortune....... hold on and ill ring them..........£45 plus vat!!!!
Thanks
Lee
Bo Bo
TheBoy's not a million miles away.....
QuoteTheBoy's not a million miles away.....
Tech2 cannot do the IR ones, so you need to find someone with a Tech1 or a generic one. Try some autolocksmiths...
sir moanalot
im desperate for a spare, am getting a blade and looking for a 3 button remote unit for a 2000 (sep) x reg cdx 2.5 saloon, what sort of remote would i have to get?
Quoteim desperate for a spare, am getting a blade and looking for a 3 button remote unit for a 2000 (sep) x reg cdx 2.5 saloon, what sort of remote would i have to get?
The same make as your existing one, which for 3 button ones, I believe is Megamos or Delphi. The 2 kinds are not interchangable...
OMEGA VXR
Hi TheBoy
Do you know of any that can programme my fobs in the Leicester area? ive rang 3 companies this morning with no avail -they tell me that my fobs cannot be programmed cos they are second hand, im sure they're talking crap!
Also they say i need my car pass which vx say i dont need it, it was never with the car when it was registered (they checked chassis no.), if this helps ive got a IR dome next to the electric sunroof switch and the fob numbers-
The fob is a kiekert IR 2, GM no 90 459 461, 90 460 834
Thanks
Lee
Phil
#6
Don't you program this type by sitting in the car with the ignition on, and locking and unlocking the car via the remote?
It will say in the hand book, or was in my Vectra which IIRC is the same type.
OMEGA VXR
Hi Phil
Ive tried that matey, it is in my hand book but thats for when you replace the batteries,
i.e not changed the batteries in the required time, i think it says you have 3 minutes then you re- programme the fob the way you said.
Thanks for your help though
Lee
Interesting. You know that one of mine we farted about trying to get to work at the weekend?
Both looked like Delphi remotes?
The original key is in a Delphi case.... With a megamos pcb in it!
someone has changed buttons then...
QuoteHi TheBoy
Thanks
Lee
No, sorry, I don't.
Tech1 required. Not sure if it needs a carpass or not on those ones....
Quotesomeone has changed buttons then...
Looks highly likely. The metal casings of the 3 buttons look like they've been butchered so someone's been in there.
I'll treat it to the buttons from the Delphi one when I've got a spare working of the correct type. They look much better.
Always thought you sat in the car with ignition on and pressed buttons?
