Headlights - European adjustment
Started by JayUK, 26 February 2007, 17:11:47
JayUK
Hi all,
I'm taking a trip over to Germany this coming weekend and having looked at the info in the manual thought it would be a piece of cake to do the adjustments.
Take the cover off - easy peasy!
Take the headlight cap off - You're joking. My car is full of engine & battery & other bits that means I can't get normal sized hands in there
Adjust the leve up or down - Not got that far yet
Now am I being thick (likely) or do the Xenon lights not need adjutsting for Europe? (hopefully)
There's no way I'll be able "pop the headlight cap off" as I don't see enough room. Never mind being able to see and adjust any lever!
Over to you, oh knowledgeable ones!  :y
J
Its easy enough....I have big hands and can do it....
Remember, the lever is behind the cap that sits on the full beam bulb....
Yes, they do need setting (presuming they are not already set that way, in which case you need to adjust back to uk on your return).
Presumably you have removed the plastic covers with the push and turn clips?  It is tight, but not impossible...
JayUK
Having just had a quick look this afternoon, I've removed the headlight cover with a coin, to get access to the lights.
Then I've got the HID unit (I guess) and the light cap which I need to get to.
I'll have another go and try to get acces to the cap on the full beam part.
On the passenger side it looked like the batter was well in the way so I'll get that out the way and see
Thanks guys, I'll report later!
JayUK
I love this place - even though it does seem to keep proving I'm an idiot.
Got it all sorted now, found the levers that I need to move and kinda figure out which way they need to be.
Thanks guys  8-)
QuoteI love this place - even though it does seem to keep proving I'm an idiot.
Thanks guys  8-)
I know its one up and one down, but can never remember which way round  :-[  - I just do it in the dark with lights shining on garage door...
DaveL
#6
Left Hand side - Lever up for u.k.
Right Hand side - Lever down for u.k.
Opposite positions for over the water. :y
8-)
DaveL
MaxV6
is that left as you look at the car from infront of it , (driver side) or left as if you were in the car (Passenger side)
this always bugs me so I'd just like someone to tell me :(
theolodian
Quoteis that left as you look at the car from infront of it , (driver side) or left as if you were in the car (Passenger side)
Yeah, I was wondering about that too!  We had a huge discussion on left/right a while back.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
I always take left & right as Haynes does ie as if you're sat in the car.
Less confusing is DRIVER'S side & PASSENGER'S side
Except we have US and EU members here....
Quote.....
Except we have US and EU members here....[/quote]
I very nearly added something to that effect  ;)
Less confusing is DRIVER'S side & PASSENGER'S side for those of who drive our Vauxhalls (or Opels in Ireland) on the correct side of the road ie the LEFT
DaveL
The sides of the car are when seen from the rear. i.e. car pointing away from you. :o
8-)
DaveL
