V6 Breather System Photos
Started by ClarCE, 27 February 2007, 13:31:52
ClarCE
Hi all,
I don't suppose anyones got any of the photos from the V6 breather system cleaning guide saved?  They don't appear when I look at it...
Cheers,
Chris.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Gaffers
I will be taking off the plenum and rocker covers this weekend.  I will have them posted by mid next week.
If you can hold out till then bud...??    :y
ClarCE
Might be able too ;)
Noticed your only up the road from me - theres a few of us omega types down this way :)
Gaffers
Certainly is, we should have some of those sad stickers done so when we pass each other on the A303 we can hang out the window and hi-5 ........ ok maybe not.....   :-/
r.welfare
#4
Looks like we might have a local subsection going  ;D
Looking forward to these photos mrgaffney, I will be cleaning out my breathers shortly...
Would be interested to know how to get the EGR valve nut (the big one!) undone, as I couldn't when I changed my cambelt and ended up disconnecting the inlet manifold from the plenum.
Chris, I'll do your breather system at the same time as the cam cover gasket change (necessary to stop gaskets blowing again).. you can see how it's done and take pics...
ClarCE
QuoteChris, I'll do your breather system at the same time as the cam cover gasket change (necessary to stop gaskets blowing again).. you can see how it's done and take pics...
Hi James, that would be ace, then when I need to do it again I'll be sorted, and of course I'll post them on here :)
ians
r.welfare,
I'll sign up for the Newbury section too (I'm in Woolhampton).
I used a big adjustable to release the EGR pipe.
Cheers
Ian
r.welfare
Thanks Ian, I tried that last time - I guess mine isn't up to the job, I'll borrow one from my neighbour  ;D
Gaffers
Quoter.welfare,
Cheers
Ian
often helps if you tap the wrench/spanner you are using.  Not too hard just enugh to send vibrations through the joint and release those stubborn ones.
sir moanalot
blooming heck, just seen your from tidworth ! that brings back memories for me -when i wore green and bossed people about!!!! tone.
Gaffers
Thats what I thought I would be doing, now its all pink and fluffy..... long tone.......
