Author Topic: What size socket...  (Read 1644 times)
What size socket...
« on: 02 March 2007, 21:05:56 »
... holds on the coolant transfer pipe.. ?
Can anyone confirm? Visually it looks like an E12.. but I'm not sure..
Matchless
  • Nottingham
    • A white van
Re: What size socket...
« Reply #1 on: 02 March 2007, 21:27:45 »
Access for a socket is very tight, try a ring spanner, 8mm fits iirc.
There is also a spacer on the bolt, note where it fits.
rpont
  • Tadcaster
« Reply #2 on: 02 March 2007, 22:02:38 »
An 8mm socket on a 1/4 inch ratchet works if I remember correctly but I'd moved the PAS fluid reservoir forward to get the pipe out of the way.
« Reply #3 on: 03 March 2007, 09:47:46 »
8mm open ended spanner......its a torx but, this is the easiest way to get at it...
