Author Topic: I am not capable of doing an oil change...  (Read 3170 times)
« on: 14 September 2007, 20:25:23 »
.... without stripping the bloody thread off in the sump!!!  >:(
Just dropped the oil, and popped a new filter on my nice Omega. Put the sump plug back in, tighten by hand, and go to nip up with ratchet. Don't get as far as nipping it up... just turns... and turns... and turns!! I now cannot remove the bolt, however hard I try.
So... off with the sump. Once I'd removed the million bolts that hold it on. Did it want to come off? Not in one bloody peice it didn't  >:(
It may as well have been welded on there.
But anyhoo. It's off.
I'll look at it in the morning, but - anyone got a spare V6 sump?  ;D
holey head
  • leeds uk
  • i'm a new dad
Re: I am not capable of doing an oil change...
« Reply #1 on: 14 September 2007, 20:30:26 »
unlucky james, you aren't having that much luck at mo are you?
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
Taxi_Driver
« Reply #2 on: 14 September 2007, 20:38:46 »
Think you did that on the veccy too  :o ::) ;D
Nooo my oil doesnt need changing  ;D
STMO123
« Reply #3 on: 14 September 2007, 21:34:37 »
I changed the oil and filter on that less than 1000mls ago.
Martin_1962
« Reply #4 on: 14 September 2007, 21:35:25 »
Helicoil time again? :o :(
Think you could my CTS bolt?
STMO123
« Reply #5 on: 14 September 2007, 21:37:20 »
Also, when you tighten the sump plug up by hand, it bites very quickly. There is still a long way to go, and it fells as if your never going to get there. I'll bet you never stripped it, just gave up before it went all the way home.
« Reply #6 on: 14 September 2007, 21:50:19 »
Yup, so it's now approaching 3k, which is when I do an oil change :)
Re. it not being fully home - I have turned, and turned, and turned it. Turn it now in either direction, and it doesn't move in or out.
It's no biggie - don't forget I have my cattle-wagon to drive around in for another couple of weeks ;D
« Reply #7 on: 14 September 2007, 21:51:03 »
Ps - many thanks for the package, arrived safely :y
STMO123
« Reply #8 on: 14 September 2007, 21:56:05 »
Dont let the dog eat them :D
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« Reply #9 on: 14 September 2007, 21:58:47 »
Will the sump on my silver '97 2.5 be the same?...if it is i can remove it for you tomorrow afternoon...Wayne
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #10 on: 14 September 2007, 22:10:15 »
Should be..
Martin_1962
« Reply #11 on: 14 September 2007, 22:13:20 »
I'd say get it off and get it helicoiled - same reason as the Vectra.
« Reply #12 on: 14 September 2007, 23:23:19 »
only problem with re-using this sump, the sump lip took a pasting getting it off..... it was solid..
STMO123
« Reply #13 on: 15 September 2007, 08:01:38 »
When I last had it off (that brings back memories :-[), I couldn't get hold of a gasket, so I super-glued it. ::)
sir moanalot
  • fens
« Reply #14 on: 15 September 2007, 08:34:42 »
i know just how you feel, last year i decided to change my front discs on my mondeo- 1 came off easily by the other would not budge.
i went out and bought a puller which promptly shattered the disc leaving a "star" in the middle. no end of pulling and bashing released it so i had to get it lifted to a local garage to get it gassed off.
the moral of my tale was a light steer wobble at braking, a quick 15 minute job, £125 later i was not amused!
hope you have better luck mate. ;)
