Transmission fluid capacity
Started by meegaveesix, 12 March 2007, 15:42:49
meegaveesix
Right, not going to chance anything with the replacement AR35 box I've bought, so I'm going to change the fluid and clean the filter out before it gets put in.
Does anybody have any idea how much fluid is needed from empty?  Just trying to work out whether I should get 1 litre quantities or whether I should buy a 5 litre bottle.
QuoteRight, not going to chance anything with the replacement AR35 box I've bought, so I'm going to change the fluid and clean the filter out before it gets put in.
I think it is about 9l, hopefully someone can confirm...
rpont
Haynes says 8.4l from dry, 4.4 after removing sump. So you will need 9l.
meegaveesix
Jesus - at nearly 8 quid a litre this is going to be expensive.  Is there a particular brand that stands out above any others?
QuoteJesus - at nearly 8 quid a litre this is going to be expensive.  Is there a particular brand that stands out above any others?
Try a different motor factor - my one is £23 for 5l of Dexron III retail price, cheaper trade...
meegaveesix
Just had a look on Ebay and 10 litres can be had for about £40 which isn't too bad.
Admin
http://www.opieoils.co.uk/performance_lubricants/fuchs.aspx
Fuchs Titan ATF 4000. 5L is £21.59 and is very good stuff (according to the all knowing one!) :)
The Administrator.
rpont
#7
Just in case you aren't aware it must be Dexron III or equivalent.
The Fuchs Titan oil is bloody superb stuff.....
BigCat
Quotehttp://www.opieoils.co.uk/performance_lubricants/fuchs.aspx
Can you mix it with Dexron III?
[move]The first 90% of a job takes 90% of the time, the last 10% takes the other 90% of the time.[/move]
rpont
#10
The Titan ATF 4000 is Dexron III equivalent so yes you can mix it with Dexron III.
Admin
#11
QuoteJust in case you aren't aware it must be Dexron III or equivalent.
Err yes...   ;D
Quote[Can you mix it with Dexron III?
Well considering this is a Dexron III oil too, yes it is absolutely fine.
The Administrator.
Am I looking at the wrong bit or has it gone up to £23.99 since you last bought some?  :-?
