Oil Change V6 paper filter
Started by jamie, 12 March 2007, 17:25:41
jamie
Hi
Replaced the oil filter on 3L with paper filter element, any one know the correct torque for the lid?
Some pictures of my filter here, same location as the cartridge type, detailed in the great V6 oil change guide.
http://www.iecd.co.uk/ScratchPad/OMEGA_V6_PAPER_FILTER/
MV6 3.0L  XJ40 3.6L Sovereign (Galaxy Tdi130)
My non commercial Projects http://www.iecd.co.uk/ScratchPad/Projects/NonCon.htm
Some Pictures
http://www.iecd.co.uk/ScratchPad/temp/
It tells you on the lid.....15Nm....
jamie
I just spotted that, obviously before you replied  :)  And have reduced the torque accordingly.
Some Pictures
Ahh, I've got one of these beasties on my car. Any pitfalls to look out for when changing it or is it straightforward?
QuoteAhh, I've got one of these beasties on my car. Any pitfalls to look out for when changing it or is it straightforward?
Yeah, some stupid idiot dealer would have done it up to 10 million Nm, and you'll end up cutting the thing off  >:(
QuoteYeah, some stupid idiot dealer would have done it up to 10 million Nm, and you'll end up cutting the thing off  Angry
Ahh, that old chestnut.  :(
Markie
EXACTLY !!!!
Had to dremel the one off project veccy sri
Anyone know where to get these or a part number? Also heard there was  kit to change it so oyu can use normal filter...?
QuoteAlso heard there was  kit to change it so oyu can use normal filter...?
That would be a good move. I can't think why they didn't just use a cartridge filter in the first place like 99.8% of car manufacturers. Last time I saw a paper filter it was on a vintage tractor!
Germans trying to cut down on the bit of metal they have to throw away every oil change, no doubt.
I wouldn't mind if the filters were cheaper but there doesn't seem much price difference.
Early ones were spin on type (£1.11 TC), later used the paper filter (£3 ish TC)
Markjay
#9
EXACTLY !!!!
Easy Peasy. Mine came off using nothing more than a 450mm breaker bar. >:(
Alas, no more Omegas....
QuoteEasy Peasy. Mine came off using nothing more than a 450mm breaker bar.
Hmm. My car allegedly got a 40,000 mile service when I bought it. Previous to that it was laid up for 18 months so it hadn't been off for quite a while. The area around the oil filter looks remarkably free of any oil spillage, making me wonder if they bothered to change the filter at 40,000. The oil is certainly clean...
Fun and games ahead, methinks.
Markie
good luck - you'll either need it - or wonder what the fuss was about ;)
Dave-C
Being an ex Ford man, having many v6's and Pinto's over the years, I've always fitted canisters to the torque of, good hand tight then a little bit more, i.e. literally by hand, so much so, when I came to do the next oil change they were still hand tight and dry, where's the bloomin' logik in bollokin' 'em um megga tight.. I also think that, oiling the o ring prior to fitting helps too..
DC
Well, I guess since the housing has a hex nut shape on it the average garage gibbon does it up with a wrench as tight as he can!
QuoteWell, I guess since the housing has a hex nut shape on it the average garage gibbon does it up with a wrench as tight as he can!
Even though it says 14Nm on the casing....  >:(
