Author Topic: Diff Pinion Oil Seal Change  (Read 2653 times)
Sir Sideways
  • Sideways in Staffordshire
    • PFL 3.0 Auto Elite Estate
« on: 15 March 2007, 18:33:36 »
Hi All,
Im gonna be replacing my seal on staurday and i have a couple of questions:
What size is the diff pinion nut? do i need a deep socket to fit on to it?
when replacing the diff pinion nut, is there a torque setting i need to set it at? or is it a case of line up the punch marks?
Thanks for any help guys
Thanks go to Marks dtm Calib for the how 2  :y.
Re: Diff Pinion Oil Seal Change
« Reply #1 on: 15 March 2007, 19:36:56 »
You need a 30mm deep socket and a 3 legged puller....you fit the nut back to where it cam off i.e. line the marks you made up and count the turns.
Its worth checking the oil level first just in case it has to much in it....
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 16 March 2007, 10:47:15 »
Use a bit of spray paint etc to mark the propshaft-dougnut-pinion flange alignment.
Make sure that you mark accurately between nut and flange before moving the nut and again between flange and pinion shaft before removing the flange.
You will be applying lots of force so make sure the car is properly supported, I used ramps which made access to one of the propshaft bolts difficult but meant that I didnt need someone to press the brake while undoing pinion nut. You could bolt a length of angle iron to the flange to hold it still if you have to do it with the wheels raised.
You will lose some oil so check level and top-up afterwards.
Sir Sideways
« Reply #3 on: 16 March 2007, 13:13:06 »
ok thanks guys im gonna give it a go
jim
Sir Sideways
« Reply #4 on: 17 March 2007, 13:47:09 »
SUCCESS!!! :). Took around 6.5 hours (garage quoted 5 hours). took my time and hey presto no leaks and all new oil. Not much oil came out once the seal was out maybe less then a quarter of a litre, which i found to be quite a shock because it wouldnt of been long before it would have been bone dry  :o.
Big Thanks go to Marks DTM Calib for the ace how 2  :y :y :y
Jim
P.S next up: Gearbox Oil Change  :-/
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 17 March 2007, 15:50:48 »
Jobs a good 'un :y
Well done :)
I like red cars
« Reply #6 on: 17 March 2007, 19:57:24 »
Cracking job.  I think Tunnie may become your best mate, as his needs doing....
Ken T
  • Stockport
« Reply #7 on: 18 March 2007, 00:08:20 »
Me too, my car sailed thro its recent MOT, but when it was up on the ramp I noticed the Diff a bit wet. What size hammer do you use.........
« Reply #8 on: 18 March 2007, 12:35:39 »
Yes!!
6.5 hours though  :o
I am too scared to touch the diff, I have a tendency to snap bolts  :-[
Sir Sideways
« Reply #9 on: 18 March 2007, 15:18:08 »
It took that long because I had to pop out for the puller (20 mins). It took around 20 mins to get car set up on ramps.  I was also stood around talkin to my cousin while the oil dripped out, prob could have had the job done in around 4 hours. The garage also reckoned they would have to drop the exhaust too, but I didnt.
I used a little tac hammer to start off putting the seal back in then moved on to a rubber mallet with my secret weapon to get it in until there was enough thread to get the nut back on and pull it all the way home.
Jim
P.S Tunnie, I was scared of snapping bolts too but, i got a lot of force on them and they stood up to the job, a torque rwrench would be ideal, except on the diff bolt itself.
