Rattling pair of Pins
Started by Boiler Man, 23 March 2007, 11:02:13
Boiler Man
Hi Guys
Dont know if its just me or has anyone else had their Door Lock Pins rattle and buz when on the move.
They quite down if I lock them down.
Any ideas for why they are doing this or how to stop it? :y
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
I've noticed this too. Right where your ear can pick it up  >:(
I remember seeing something about fixing it on here. I'll have a rummage. In the meanwhile maybe soneone will come along who's fixed it.
Boiler Man
Cheers I would appreciate any advice
Sorry forgot to mention its a facelift model :-[
Yes....the best solution is to pop the door card off and place a bit of sticky back draught excluder to the door metal work where the rod to the button passes
Boiler Man
#4
Cheers for that :y
When you say pop the door card off, do you mean the whole interior door panel?
If so, Is it a big job. lots of screws and wire etc?
Not done that yet on this model. :-/
ClarCE
Yea, its the interior card - easy enough - in fact I've found it easier on this car than any other.  Think theres a guide somewhere that talks about the removal at some point.  Only trouble I had was getting my hand inside to reconnect the courtesy light at the bottom as the lead was short and unplugged itself during removal.
Think there are screws all around the edge, behind the handle and the ashtray, at least this was the case on the rear drivers side door.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Facelift door has a hidden screw. I think there is a guide in Maintenence Guides for door card removal.
Dave-C
If it's just the door lock pin in it's holder on the top of the card, there is a tiny piece of "Fuzzy Felt" it it, that gets compressed...  remove the pin by prizing off the red insert, the pin will lift off, on the rear is a groove withe the afore mentioned in it, pull it out, puff it up, refit..  seriuosly that's all I had to do to stop my annoying rattle, failing that, Marks got the best idea..
DC
Omega 1999 mini facelift
Chopsdad
#8
I had them.  Bloody annoying  >:(
Fixed by replacing them with a set of aluminium ones like these http://cgi.ebay.co.uk/ALUMINIUM-DOOR-PINS-MERIVA-CAVALIER-MK3-TIGRA-A-SIGNUM_W0QQitemZ160099388613QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Now they don't rattle anymore and look good too.  :y
There is a red square in your door pins that just pops off with the help of a small blade, the new ones attach with allen screws.  Easier than removing door cards imho.  I did have to drill the core a little more on mine to make the sit at the right height, but I'm sure you can do the same if you need to.  :)
spiridusul_rau
QuoteYes....the best solution is to pop the door card off and place a bit of sticky back draught excluder to the door metal work where the rod to the button passes
Hi Boiler Man,
glad to know that others have this problem. Next weekend I will follow "Marks DTM Calib" advice. It is very easy to remove the interior door panel.
Taxi_Driver
I wondered why the drivers door lock on mine is shorter than the others....maybe the previous owner had the same prob....and its been 'fixed' somehow  :-/
