Author Topic: What is this pipe?  (Read 1900 times)
    • E250 Est / Elroq
What is this pipe?
« on: 02 April 2007, 14:48:53 »
While searching for my coolant leak, I spotted a little vacuum pipe at the front of the engine, sort of at the bottom, below the air filter box, which was not attached to anything, and had a 13A fuse stuck up its end to block it.
It is the length of a similarly routed pipe which goes to a roughly 6" x 6" x 2" box.
What is this pipe and where should it be.
If needs be I can get a photo.
If I reference the piccy in http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
It looks like the front vac resivoir, mine has 1 pipe to it, should it have 2 and this is the 2nd?
What effect would it not being connected (or reconnected) have?
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
Re: What is this pipe?
« Reply #1 on: 02 April 2007, 15:21:26 »
It should have two connected, you are correct.  One of mine snapped when I last took it off, I recconected it my shoving it into the vac tank through the hole that the pipe left when it broke.
Sealed it with a bit of spray adhesive, its in there working and not leaking - I would say you need to get that plugged back in to get the car to behave as it should be..
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
    • E250 Est / Elroq
« Reply #2 on: 02 April 2007, 15:26:12 »
Cheers, will have a rummage later
    • E250 Est / Elroq
« Reply #3 on: 02 April 2007, 18:17:52 »
All the above confirmed, compared to Pete's Elite.
Now to work out how to fix broken connector.
The Barge Captain
« Reply #4 on: 02 April 2007, 23:03:29 »
I found mine was broken, so i found a 2" long piece of hard plastic of a suitable diameter to fit snugly into the vacuum pipe, cleaned up the broken hole in the resevoir, then using araldite, glued the "new" stub into place.  Job done all for a few pence.
    • E250 Est / Elroq
« Reply #5 on: 03 April 2007, 07:50:35 »
Im thinking something similar.....Or get one from a broken meega
Want a few other bits as well, so may do a parts wanted ad.
What changed when it was fixed? Better low rev performance?
