Front Pads Wear Sensor
Started by Padster, 03 April 2007, 17:14:54
Padster
Hi all, i attempted to change front pads today, but i noticed a cable running into the top of the inner pad (i assume it was the wear sensor) and couldnt get it out of the hole. After much brute force, i abandoned ship as i couldnt get the little rascal out.
Do i need to buy two new ones and connnect them to the "plug" which clips to the inside of the wheel arch? (I followed the lead and saw a black tubular connector half way up the arch)
If i do need to buy them, any ideas how much they'll set me back?
** Kenwood Head Unit + 12" Kenwood Sub / Vibe Amp ** Hillper's Boot Mod ** HID Coversion **
Taxi_Driver
You only need the one for a 2.2......mine was about £6-7 but that was on TC.....not sure of retail price sorry  :(
Taxi_Driver
Should add, always worth getting one.....as your about to find out....it will snap off fairly easily.
Padster
I only need one? Would that be the one on the front nearside then?......... The one that crumbled like icing on a dry cake?!!?!? ::)
I just paid £20 for two on my mini facelift 3.0 :'(
Taxi_Driver
QuoteI only need one? Would that be the one on the front nearside then?......... The one that crumbled like icing on a dry cake?!!?!? ::)
Yep thats the one....only the one on facelifts....2 on prefacelifts....and looks like 2 on mini facelifts
Taxi_Driver
QuoteI just paid £20 for two on my mini facelift 3.0 :'(
2 up to around 2001, 1 on later cars.
Same part for all cars, with exception on early 2.0l...
BrianH
Mines a 99 V6 mini facelift last time I changed Discs and pads about 6 months ago sensors cost about £13 for 2 but they offered me a choice of 2 types .I think ceramic bit was different shape and colour also connector different shape. These were purchased from Southern Motor Factors and if I remember from previous time from Vauxhall worked out about 1/2 price.
Brian
Omega VT3000
I think you can buy them for about £4 each from Motaquip if that helps, it may be worth asking before spending Vx money.
Where from? I bought a couple recently for my Omega, & although I can't remember off the top of my head how much .... they weren't £20!
£20 ish is about right for a pair from Vx at retail prices....
Quote£20 ish is about right for a pair from Vx at retail prices....
Oh!  :( I must have been cosseted with the TC for too long.
Saving is about £3.50 per side on TC
ians
I seem to remember getting a pair from Halfrauds for just over a tenner - not bad I thought.  Had to order them though.
This is one of those classic Haynes 'unclip the wear sensor (with the back of your fingernail...)'  type jobs that turn out to be minor b@stards.   and I never did really figure out how to install the new one with the caliper fully assembled - seem to remember having to feed the sensor in with the caliper partly off if that makes sense.
