gearbox conversion.
Started by bogit, 05 April 2007, 08:17:52
bogit
just thinking out loud at the moment,
has any one converted there meega from slush box to stick ? :-?
dash bulbs replaced,ecc sorted,atf to go, door blowers-maybe
Quotejust thinking out loud at the moment,
has any one converted their meega from slush box to stick ? :-?
Why would you want to?  ::) Up clutch ..... Down clutch ..... Up clutch ..... Down clutch ..... Up clutch ..... Down clutch ..... Up clutch ..... Down clutch .....
Driving my diseasal Astra serves to remind my why I would never really want to fully revert back to 3 pedals!  ;)
What say you Paul M?!?!  ;D  ;D  ;D  ;D
bogit
it would stop swmbo from making it stand on its front wheels with the rears in the air when she forgets and goes for the clutch pedal,and lands both feet on the brake pedal  :o
and im not bothered rearly, was just thinking aloud  ;D
Matchless
I have a long term project to convert to manual box, collected all the bits but other things are in the queue first. Also want to try the later autobox software before I make the final decision.
It isnt a difficult job if you are OK mechanically but you really need access to a donor car for the bits, working from a breakers yard would be difficult to get all the little bits.
Mole
I've just done the manual conversion on my mv6 and although it's straight forward enough there is a lot of bits to be changed. Ideally you would have a donor car to sit beside your one but I sourced most of the parts from a local breakers yard. You will have to remove the gearbox, propshaft. torque converter, flywheel, brake pedal box, gear selector and associated bits of trim, ATF pipes running to the radiator and the plastic bung covering the hole for the clutch master cylinder. Then replace all those bits from the donor car. You also have to buy a spiggot bearing for the rear of the crank as automatics don't have one.
I did the lot in a weekend and a couple of evenings and the car feels so much the better for it. The only problem I haven't addressed yet is the MID which displays AUTOMATIC GEARBOX when I first move off after starting the car.
