Is this normal
Started by omegalyn, 05 April 2007, 13:02:10
omegalyn
Changed the Cam sensor last week on my 2.0 Ecotec 16V, had a good look at the cam belt as this needs changing soon.  I started the car to see what direction the belt runs and noticed that the pointer behind the belt tensioner was moveing from side to side. It's the arm you line-up with a markings on the backplate when adjusting the tentsioner. Is this the norm?
Thanks
Lyn
ians
Yes it is normal as the engine goes through its cycle.
cheers
ian
omegalyn
Thanks Ians, Just wanted to conferm. :y
ians
FYI I've done the belt a couple of times - pretty straightforward really.
omegalyn
Yes, Going to have a go after I get a torque wench.
Admin
Just please change the water pump at the same time as this is driven off the cambelt.
The Administrator.
omegalyn
Good thinking, thanks
QuoteGood thinking, thanks
Lyn, Where in wales are you? I'm often in Wales myself, if it's anywhere nearby I could pop over and change the cambelt kit / water pump on your 4pot.. not a tricky job.....and I have the locking tool
omegalyn
Thank you for your offer James, have sent you a PM.
Lyn.
