where is it safe to jack for very short periods
Started by bogit, 05 April 2007, 08:15:25
bogit
i need to get the front end of my cr up in the air so i can look at my auto box leak,
i think the safest way is to get to work and use the commercial vehicle jack there.
now is it safe to jack the car up on the sump of the engine, or either of the two cross members for very short periods of time, ie untill i can get the soddin great axle stands at work under the rails of the car ?
dash bulbs replaced,ecc sorted,atf to go, door blowers-maybe
nixoro
You should have a jacking points on both sides of the car, they are directly behind the removable plastic sections to the sills you can usually get the small disc on the jack in these but if they are bigger it should still be ok.
I wouldn't jack the car up going anywhere near the oil sump or the two cross members as the jack could easily slip causing more damage.
bogit
#2
trouble is,ill have to use those points to jack the car up with my little trolley jack,to get the car high enough to get the huffin great 15tn trolley jack under the car, things got a disc on top of it the size of a plate :)
Quote..., thing's got a disc on top of it the size of a plate :) ........
Looks more like the size of a cup to me!  ;D  ;D  :y
bogit
true, but it is a special workshop cup, holds about half a pint of tea  ;D
nixoro
Quotetrouble is,ill have to use those points to jack the car up with my little trolley jack,to get the car high enough to get the huffin great 15tn trolley jack under the car, things got a disc on top of it the size of a plate :)
Ah I see what you mean could you not get away with putting a piece of wood on the jacking plate
Look directly inwarsd from the front jacking point and you will see a main chassis member you can use this adn its big enough for both jacks....
QuoteLook directly inwarsd from the front jacking point and you will see a main chassis member you can use this adn its big enough for both jacks....
You can use this for normal jacks...
Do not jack on the sump!!!
You can jack on the main cross beam (i do), but you need a deep jack for this. That goes back beyond the sump  :y
Danny
ohhhh.. you meant getting the car up?
when I read the topic I had a completely different thought!  :o
bogit
Do not jack crossmember on Omega, it will bend...
I've seen it been done?
Senator its fine, also on Omega's .... :-/
The crossmember is not designed or strong enough to take the weight in that direction...
Omegatoy
Well then i have been doing it wrong for the past god knows how many years!!
its designed to carry the full weight of the car, and its bolted to the chassis rails, the load is spread on all four mounting points its absolutely no problem jacking it on the crossmember proividing you have a large pad on the jack!!!
have always jacked it in the middle of the member both TDs and the Megameega no problem at all and when i changed the engine mounts it had an axle stand under the middle of it, apart form a few scratches on the member nothing else has happend!!
Omegatoy
Chopsdad
Quoteohhhh.. you meant getting the car up?
Cheeky  ;D ;D
