Help! Project TB2 - Update 6
Started by TheBoy, 10 April 2007, 19:45:28
x25xe
Just a wild idea / long shot / stab in the dark etc. - and probably wrong - but is there a hose that is collapsing when hot?  This would either severely reduce or even stop the flow of coolant.  It would also increase the pressure................  Are any hoses pinched in some way i.e. caught between ancillaries / engine components etc?
It is possible I suppose that the 3 caps are damaged in some way due to excess pressure but somehow I doubt it.
Finally, sorry if the above is plain stupid but it is all I can think of!
QuoteJust a wild idea / long shot / stab in the dark etc. - and probably wrong - but is there a hose that is collapsing when hot?  This would either severely reduce or even stop the flow of coolant.  It would also increase the pressure................  Are any hoses pinched in some way i.e. caught between ancillaries / engine components etc?
All posts gratefully received, read, and considered :y :y
The coolant system on the tractor appears to be around the engine, 1 think hose from head to rad, the rad, 1 think hose from rad to stat, stat to engine (obviously the pump somewhere in the block as well).
So only 2 hoses are the 2 big ones from to/from rad.  They do look absolutely fine though.
x25xe
OK
Another thought - you have replaced the original expansion tank with one from a V6.  A further long shot - I wonder is the design pressure for the expansion cap is too low?  If it is this would explain the cap blowing off and loosing water.  It would also explain the overheating as, when the pressure is released by the cap, the boiling point of the coolant is reduced.
As I say, another long shot, but worth considering.
QuoteOK
Often the pressure is stamped into the cap itself.
QuoteOK
Its running a v6 expansion tank, as the diesel one suffers the same symptoms...
Matchless
Its not stupid, I had a car where the hose collapsed internally (they are made of two layers of rubber sandwiching a fabric layer) from outside it looked OK but the bore was almost completely blocked by the inner layer which had separated from the fabric part.
Only clue was that it felt very soft to squeeze.
Right then, went to Towcester to go shopping, about 10 miles away, all dual carriageway, kept it at constant 70mph. Bear in mind I currently have the drilled stat in.  Stayed below 90 degrees most of the way, couple of times did go up to 92ish.  On arrival at Tescos, I had lost probably 1l of coolant, nicely sprayed around suspension strut and airbox.
So we did our shopping, and I then filled the coolant back up, and put on the cap that Omegatoy got from the diesel in the scrappy.  Drove back, constant 70mph, temperatures same as before, mainly near the end stop, but occasionally rising up to 92ish.  However, upon arriving home, the cap was hissing (this cap even hisses when you drain coolant, but forget to remove cap, so I had written it off as knackered), but had lost minimal coolant.  Undoing the cap slightly, and it did exactly what I would expect a hot car to do - hiss voilently, and start to boil in the bottle.  Radiator was hot all over - too hot to hold for too long.
Feeling like a better test was needed, I wired up the leccy fans (and the intercooler fan) and took it for a decent thrashing, only to be prevented from doing so by today's ridiculously slow drivers.  Opened it up when I could.  Temp was around 90 - 92, dropping back down to endstop whislt following grandma and grandad.  Again hissing, but minimal coolant loss (though defo still some)....
Auto Addict
I was nowhere near you today..... :-?
I like red cars
QuoteI was nowhere near you today..... :-?
Not you AA - you drive at 45 everywhere. These idiots were crawling. I could have pushed the car faster!
Omegatoy
QuoteRight then, went to Towcester to go shopping, about 10 miles away, all dual carriageway, kept it at constant 70mph. Bear in mind I currently have the drilled stat in.  Stayed below 90 degrees most of the way, couple of times did go up to 92ish.  On arrival at Tescos, I had lost probably 1l of coolant, nicely sprayed around suspension strut and airbox.
Hmmm thats interesting, with a lot of holes drilled you effectively have permanent flow ignoring the bypass system, wonder if the new stat is faulty? the answer is here somewhere just cant get it out in the open yet!!!!
My current theory is all my caps are faulty....
Auto Addict
Why not run it without a thermostat?
I like red cars
Omegatoy
I suppose its possible that they were all exploded with teh original blocked radiator/ seems strange that you loose minimal coolant with the diesel one tho in spite of its hissing all the time?
QuoteI suppose its possible that they were all exploded with teh original blocked radiator/ seems strange that you loose minimal coolant with the diesel one tho in spite of its hissing all the time?
I had written the diesel one off as faulty, as it even hisses when you undo the rad drain screw with the cap left on...  :-/
But it does seem to be the best cap  :-/
Maybe you could try my cap(s) and see what you get?
Omegatoy
would rather you tried mine!! i have new antifreeze in and dont want to lose it!!! give you a text when i get home tomorrow as i have a short day!!!!
