Author Topic: It has been done at last.  (Read 4804 times)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« on: 15 September 2007, 19:02:02 »
 Today i had the 3.0ltr cams fitted to my 2.5ltr.I am going to take it for a run tonight to see what the car performs like. I will post up a more compleat  report later.Regards Gary. :y
Jaguar XJ6
Re: It has been done at last.
« Reply #1 on: 15 September 2007, 19:03:00 »
Please do mate.
If it's worth it to a huge extent, I will also get some for mine...
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #2 on: 15 September 2007, 19:05:14 »
I intend on getting some for mine aswell, and then replacing the autobox with an AR35 for a bit of extra strength :)
Humbugs...
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 15 September 2007, 19:05:36 »
Please do mate.
You just sold some ::)
paul.c
  • east calder scotland
  • hands off shes mine
« Reply #4 on: 15 September 2007, 19:07:37 »
do you know if it will raise the bhp if so how much. or does anybody else know :)
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #5 on: 15 September 2007, 19:08:35 »
they do have an effect, but like anything they work better if they are coupled with a few other mods.
An enlarged throttle body and a 4 bar adjustable fuel pressure reg that had been set up correctly, decats and a mildly sporty stainless system and a pipercross viper induction kit created 202bhp out of a FWD V6, once the chip had gone it then it was 210bhp.
the biggest cost was more time to set it all up, i reckon about £300 all in before we got to the chip and that included a cambelt kit
« Reply #6 on: 15 September 2007, 19:09:23 »
I know I did :(
Did you get your camcovers ok?
Dazzler
« Reply #7 on: 15 September 2007, 19:18:47 »
I know I did :(
Not arrived yet :'(
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #8 on: 15 September 2007, 19:19:14 »
Sounds great, looking forward to an update :y
« Reply #9 on: 15 September 2007, 19:31:49 »
About a 20Bhp rise with no extra mods required....
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #10 on: 15 September 2007, 19:34:47 »
how would an AR25 cope with that?
« Reply #11 on: 15 September 2007, 19:40:07 »
Its a cam change......not a massive torque increase but the existing torque peek moved further up the revs to give more bhp (BHP=((Torque x Revs)/5252) so should be ok.....
Martin_1962
« Reply #12 on: 15 September 2007, 19:43:44 »
Which cams are in a 2.6?
« Reply #13 on: 15 September 2007, 19:53:31 »
I know I did :(
Not arrived yet :'(
Maria? Can you confirm they went first class on Friday as requested?  :-/
ffcgary1
  • Mitcham,Surrey.
« Reply #14 on: 15 September 2007, 22:05:41 »
Well just got back from a quick splat to Epsom downs and back, and i have to report that the cams do make a huge differance to the " driveability " of the car. First of all the car is more responsive to the throttle, and pulls more cleanly right through the rev range up to about 6,500 rpm. The engine also sounds as though it has lost it's wheezzze noise and has more of purpusfull suck if you know what i mean. The cars work was done by a good pal of mine who is a platinum std vx mechanic and earned every penny of the stupid money he asked for, so a big up to you Alan 'blakey' Kent. Whilst he was doing the swap i stripped the throttle body off of the plenium and cleaned the butterflys and internals, i was supprised how bad they were considering how often i service the car. The breathers were removed and i cleaned them along with the pipe that goes down to the breather box and refitted to the plenium, with all new o rings.So i am no longer a breather virgin anymore. We also fitted a gas flowed 3.0ltr inlet manifold and 3.0 injectors along with a 4 bar fuel pressure regulator. A new gen vx cam belt kit was fitted, aux poly belt as well and a new water pump while the front was stripped out. All new inlet to plenium o rings and cam cover gaskets  replaced of course.The car is currently running with forte coolant flush in the system at the moment and will be flushed out over the next few days and filled with vx red antifreez.Finally the header  tank was replaced as it had started to crack around the neck. Here are a few pics of the work As it happened.i reccomend the mod to anybody. Regards
Saurday morning donor and recipent cars
3 ltr being stripped
2.5 being stripped
2.5 plenium full of dirt
2.5 throttle body prior to cleaning
Alan "Blakey" Kent Top Man
Gas flowed inlet manifold in place
2.5 throttle body after cleaning
Timing marks bang on
                                                            Gary  :D :D
Jaguar XJ6
