Author Topic: TrafficMaster  (Read 9097 times)
Dean
  • Weston Super Mare - UK
TrafficMaster
« on: 13 April 2007, 10:50:01 »
I have recently re-subscribed to traffic master however its not giving traffic info
When i press the button it says "trafficmaster" and i can change from manual mode to Auto mode and adjust the volume but thats it....no traffic information!
Does anybody know how i can test this thing (special menu's) or something - or has instructions?
Regards
Dean
Free Traffic law advice  - Just PM or see the sticky thread in General Chat ! http://www.omegaowners.com/forum/YaBB.pl?num=1177278724 - no liability accepted
    • E250 Est / Elroq
Re: TrafficMaster
« Reply #1 on: 13 April 2007, 10:52:32 »
Go and sit in a traffic jam and see what it tells you ;)
Sounds right to me, would say license expired otherwise.
Only had 2-3 months exposure to traffic master until it expired, not useful enough to us to renew it.
It may well be in Auto, just has nothing to say, presume the button LED is green as well now, not blank, goes red when there is a problem.
Only speaks when there is a local problem.
If you need it, I can probably dig out a manual over the weekend and scan if its not to big.
« Last Edit: 13 April 2007, 10:53:30 by jimbob »
Dean
Re: TrafficMaster
« Reply #2 on: 13 April 2007, 11:15:44 »
Thanks for the reply. I have done a 800 mile journey recently and it did'nt pipeup once... there is no illuminated green light on the switch. Does that mean its knackered!
Dean
    • E250 Est / Elroq
Re: TrafficMaster
« Reply #3 on: 13 April 2007, 11:27:08 »
Does sound like its not getting any info, should be a led build into the bottom of the switch that changes colour.
Ill try and dig out that manual.
If you go to the renwal page on the traffic master site, it details how to get its license number, which can only be done if yours has expired, so you could try that routine to prove if you have a license or not
Dean
Re: TrafficMaster
« Reply #4 on: 13 April 2007, 13:35:49 »
i definately have a licence, i phoned trafficmaster and did it over the phone a few weeks ago, entered the new code etc and she said all was fine. explained how to do the manual and automatic mode thing and i assumed that was it.
Re: TrafficMaster
« Reply #5 on: 13 April 2007, 15:24:35 »
Aswell as the green light you should get a bleep noise when you drive past the first blue mast you see at the side of most A roads.
Dean
Re: TrafficMaster
« Reply #6 on: 13 April 2007, 16:11:44 »
no.... bugger what can be wrong with it then. I know its not the best system in the world but i like things to work when they are fitted!
Markjay
  • London
Re: TrafficMaster
« Reply #7 on: 13 April 2007, 17:45:34 »
If it just says 'Trafficmaster' and no green or red light, then it behaves as if it thinks it is working but does not receive any traffic data. If you are sure you are on roads that suppose to have Trafficmaster transmitters, then your box may be faulty (it is behind the kick-panel - iirc on the driver's side?), or maybe it lost it's aerial connection.
Alas, no more Omegas....
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: TrafficMaster
« Reply #8 on: 13 April 2007, 17:53:26 »
on both omegas I've had with it fitted, the box was cable tied to the heating duct above the pedals ...
Dean
Re: TrafficMaster
« Reply #9 on: 13 April 2007, 19:29:12 »
Thanks, will take a look and see.  ;)
Markjay
  • London
Re: TrafficMaster
« Reply #10 on: 13 April 2007, 19:32:02 »
Markjay
  • London
Re: TrafficMaster
« Reply #11 on: 13 April 2007, 19:37:52 »
« Last Edit: 13 April 2007, 19:44:43 by markjay »
Markjay
  • London
Re: TrafficMaster
« Reply #12 on: 13 April 2007, 19:38:38 »
Markjay
  • London
Re: TrafficMaster
« Reply #13 on: 13 April 2007, 19:39:13 »
« Last Edit: 13 April 2007, 19:42:18 by markjay »
    • E250 Est / Elroq
Re: TrafficMaster
« Reply #14 on: 13 April 2007, 20:39:12 »
that saved me a job, was about to do that, cheers
