just plugged in my new tech 2....
Started by sir moanalot, 03 March 2007, 09:18:49
sir moanalot
and come up with errors 57 icv interruption and code 165. so what does interruption mean and how do i rectify it and i cannot see a code 165??? i tried to clear them but they both came back. also the idle is spot on- even with changes like putting on aircon, heated windows etc. bit of a mystery
57 is icv voltage low.  It will use set value for it, rather than actuals.  Problem with ICV normally, but could be loom has worn through.
165, no idea, not in TIS
Are these faults showing as 'present'
sir moanalot
i think it said 57 was present. i will recheck later. god knows what 165 was?
wakeyomega
I've also just bought the Tech2 lead and software (part english / part hungarian), and have the same 2 fault codes present in the engine section (57 and 165), which would suggest that they are down to ropey software and I would guess can be ignored.
I have , however, managed to clear a rather annoying airbag light that has been on for a few weeks (no, i didn't remove the bulb  ;) )
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Dave-C
Quote57 is icv voltage low.  It will use set value for it, rather than actuals.  Problem with ICV normally, but could be loom has worn through.
Could this be just a sh1tty connection, causing an HR.. ??
DC
The Cambelt Kid
#6
QuoteI've also just bought the Tech2 lead and software (part english / part hungarian), and have the same 2 fault codes present in the engine section (57 and 165), which would suggest that they are down to ropey software and I would guess can be ignored.
Pat
Hey Chaps,
Sorry to barge in on you like this... but i am keen to know what tech2 kit you are using?  I would imagine it's not the original kit as that costs a fortune.  I was wondering if you were using somthing like this -
http://cgi.ebay.co.uk/Opel-Vauxhall-Diagnostic-Interface-Tech2-OBD2-Tech-EOBD_W0QQitemZ110115559603QQihZ001QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Cheers
Marc
[color=green][size=18]Project LP6 has landed![/size][/color]
[color=black][size=12]DIY LPG now finally complete!! Whoo hoo.[/size][/color]
wakeyomega
This is the one I have just bought of Ebay
http://cgi.ebay.co.uk/TECH2-Diagnostics-KIT-for-Vauxhall-Tech-2-UK-seller_W0QQitemZ110117141511QQihZ001QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The software is far from ideal. Works Ok on engine and some ancillary area's, but some of the displayed areas / results are in hungarian, which means you cannot use all facilities.
I noticed a thread elsewhere talking about Opelscanner, which looks much better software, however I looked at the product and its 350 euros (you get what you pay for I guess).
Pat
The Cambelt Kid
Cheers,
They both look simular to me, just another seller!
I wonder if you can enable things like cruise at all?  I plan to enable cruise on mine soon.
with regards to your 'hungarian' bug, why not try an download the latest software from the link on ebay?  or better still why not use this link...
http://www.translation-guide.com/free_online_translators.php?from=English&to=Hungarian
szia , a nevem törköly és nekem nagyon rossz -m van nagy fej , csak kérdez feleségem!
I have the real thing :D
The cheapo lead can only read/reset codes, it cannot reprogram stuff (which includes doing cruise etc).  But at £30 ish, you can't expect it to...
