Author Topic: V6 Exhaust question  (Read 2287 times)
V6 Exhaust question
« on: 24 April 2007, 22:04:40 »
Cotton wool, lost of black strands in my backbox, restricting flow.
Question, do I just need to replace the backbox, or could this be coming from the mid sections?
Re: V6 Exhaust question
« Reply #1 on: 24 April 2007, 22:06:56 »
most likely rear....
« Reply #2 on: 24 April 2007, 22:08:42 »
My thoughts (and hopes) too!
JasonH
« Reply #3 on: 24 April 2007, 22:22:22 »
Omegas sound quite good without the backbox - you could try reving with the backbox off and see what happens.....
« Reply #4 on: 24 April 2007, 22:25:00 »
Carbon monoxode in car... chough... die? :P
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #5 on: 24 April 2007, 22:25:32 »
Highly unlikley to be coming from the mid section sounds like the baffles have corroded in the back box and the wadding has escaped
jonathanh
  • coventry
« Reply #6 on: 25 April 2007, 07:53:55 »
that's if you can get the back box off without dmanging the middle sections: two pipes into the back box means you can't twist the back box off.
parking near Birmingham airport for members with +250 posts.  PM for info
« Reply #7 on: 25 April 2007, 08:15:18 »
Thast what angle grinders were made for......
JasonH
« Reply #8 on: 26 April 2007, 22:57:51 »
You're both right.
It's a bugger to get the back box off if you're not doing the centre boxes. I had to cut mine off with an angle grinder and open the pipe like a banana.
« Reply #9 on: 27 April 2007, 01:41:14 »
You're both right.
Couldn't find the angle grinder.. so I dropped the exhaust and hacksawed the thing off
Even with a blunt saw - it was like a hot knife in butter!!
Just need to get a backbox now!
