Author Topic: Fuel Guage  (Read 1637 times)
miggy
Fuel Guage
« on: 28 April 2007, 16:44:01 »
Help
Over the past few days I have noticed that when I start the car the fuel guage stays on empty, if I turn the motor off and re-start the guage will work normal, this does not happen every time, only the odd occassion.
There is plenty of fuel in the car.
Any ideas what it could be :-? :-?
2002, 2.0 DTI
Pete
Danny
  • Wigan, Greater Manchester
Re: Fuel Guage
« Reply #1 on: 28 April 2007, 17:06:14 »
possibly a bad connection? are you parked on a slope at all?
does it happen even when you know you got half a tank in?
miggy
Re: Fuel Guage
« Reply #2 on: 28 April 2007, 18:03:45 »
Yep, park on a slope (drive) and even when I have half a tank.
Pete :o
Danny
Re: Fuel Guage
« Reply #3 on: 28 April 2007, 18:09:19 »
well half a tank suggests its not the slope causing an inaccurate reading, unless its a 45 degree angle!!
i reckon loose connection somewhere unless a more experienced member might know better
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Fuel Guage
« Reply #4 on: 28 April 2007, 18:11:44 »
I reckon you jump in. start the car and zoom off.  8-)
How do I know....because mine does the same thing.
Try starting the car before you put your seat belt on...that extra few seconds may be all it needs  :y
Edit. But mine's not a DTI  :-[
« Last Edit: 28 April 2007, 18:12:40 by Chopsdad »
wakeyomega
  • Wakefield
Re: Fuel Guage
« Reply #5 on: 28 April 2007, 22:29:31 »
I agree with Chopsdad, mine has aways done this since new, but only ever on the occasions I do a rapid keyturn/ignition and go. Works fine 99% of the time. I've always assumed operator error as it always occurs when I've set off so quickly.
Good Luck
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Taxi_Driver
Re: Fuel Guage
« Reply #6 on: 28 April 2007, 22:35:59 »
Mine does the same.....if under 1/4 full....it can read ok or empty on startup....mines a petrol tho....and i have no idea what causes it  :-[ I have checked a few earths around the rear light cluster but nothing wrong  :(
STMO123
Re: Fuel Guage
« Reply #7 on: 29 April 2007, 09:30:08 »
I find that if I have over half a tank, it behaves normally. Anything under a quarter and it really takes its time moving up.
Page created in 0.025 seconds with 16 queries.
