Horn connections - was disabled drivers vehicle.
Started by Bridget, 30 April 2007, 18:52:23
Bridget
Desperately looking for help with my horn connections! My '98 Reflection was modified for a disabled driver using the Guido SimplexEN/907 electronic gas ring and mechanical brake lever. I have managed to remove all the parts but can't get to the bottom of the wiring for the horn. I have one wire left from the old brake lever (which operated the horn) but I can't figure out where it should be connected at the steering column. Can anyone help, please?
"It's good to Talk, It's better to Listen"
It should connect to the rear (column side) of the steering wheel squib (circular plastic assmebly)....to pin 2 (Brown/white wire)
DaveL
Well Marks DTM Calib seems to have answered your question Bridget, all i have to say is welcome to the forum. :y
8-)
DaveL
Bridget
Thanks, Guys! Will try tapping onto Brown/White at connector before making permanent. Hope to get a chance to work on it tomorow night. Will post results when done.
Thanks for the help.....and the Welcome! Both are appreciated. :)
Bridget
 :y A big thumbs up to you guys! I have done the work and now my horn does whot it's supposed to!!
Many thanks!
