Re: LPG
Started by Taxi_Driver, 04 May 2007, 06:24:52
Taxi_Driver
QuoteHi,
I have a 2.5v6 Saloon , manual.
Want to have an lpg conversion. The questions i have got are:
1: Does LPG make you lose a bit of power? (been told that)
2: If so can i flip between lpg and normal petrol?
3: If so will i regain the performance when on normal fuel?
4: How much do they cost roughly?
Regards
Matt
1 Yes
2 Yes
3 Yes
4 V6....around 2k if you pay someone to do it
Martin_1962
QuoteHi,
Regards
Matt
Yes about 10bhp - but this can be got back
Yes
Yes but can you afford to
Depends who does it
wastedperfection
#2
How can the 10bhp be got back?
If that is right then i would consider ripping out the normal fuel tank , lines and everything else and just run on lpg
Would i get a reduction in road tax if it was just an lpg car too?
Matt
Martin_1962
LPG systems piggy back on the petrol system unless you want to replace the electrical system
Also what happens if you run out of gas?
The Cambelt Kid
V6 - 800 notes DIY.
As Martin says abov - LPG can't really run without starting on petrol.  Even if it could it'd cost sihit loads to replace existing ECU/Looms and the rest of the gubbins that make the car run on petrol!  Too much of a pain in the a*see in my book.  It's best to let the GM ECU control the injectors and emissions.
[color=green][size=18]Project LP6 has landed![/size][/color]
[color=black][size=12]DIY LPG now finally complete!! Whoo hoo.[/size][/color]
