Author Topic: Drip Drip Drip  (Read 2114 times)
    • E250 Est / Elroq
Drip Drip Drip
« on: 04 May 2007, 22:30:35 »
The MV6 has been leaking coolant for a bit, now at the point where it needs filling daily.
My mechanic friend has it at the moment, just come off the phone and its strip down time.
He has told me to get an Inlet manifold gasket (part no and price anyone?)
Is there anything else I should get 'while we are at it'?
And any gueses what the final resolution will be?
HBV replaced, no oil in water, no water in oil.
Cheers
Markjay
  • London
Re: Drip Drip Drip
« Reply #1 on: 04 May 2007, 23:39:41 »
If you look at this drawing:
http://www.omegaowners.com/forum/YaBB.pl?num=1178095004/0#14
Between the Intake Plenum and the Intake Manifold you have 6 black O-rings P/N 9118135
Between the Intake Manifold and the Intake Flange there are 3 double-hole red gaskets P/N 90501653
Between the Intake Flange and the Engine Block there are 2 triple-hole gaskets P/N 90501652
As far as I know the oil cooler cover is sealed with sealant only i.e. no gasket.
Normally there is no need to replace this gaskets unless they are damaged, though I did replace all of them as matter of course.
Other gaskets you will encounter along the way are the Throttle Body to Intake Plenum, two small O-rings at the front of the black plastic breather box, and one odd-shaped O-ring type seal just under the black plastic breather box. Again, no need to replace unless damaged (I didn't replace these).
I don't have the costs off-hand, but the red intake ones were relatively expensive, probably £6-£10 each.
See also http://www.omegaowners.com/forum/YaBB.pl?num=1177161624/0#3
« Last Edit: 05 May 2007, 00:11:08 by markjay »
Alas, no more Omegas....
Markjay
  • London
Re: Drip Drip Drip
« Reply #2 on: 04 May 2007, 23:40:37 »
...sory, i am assuming you are referring to the MV6, not 2.2CDX?
Also, I was referring to an oil cooler job, if it is only the HBV then the Intake Plenum does not need to come off (although access will obviously be easier if it did) - removing the wipers scuttle board should be enough.
« Last Edit: 04 May 2007, 23:43:52 by markjay »
ians
  • Reading
Re: Drip Drip Drip
« Reply #3 on: 04 May 2007, 23:51:54 »
Where is it dripping from?
Re: Drip Drip Drip
« Reply #4 on: 05 May 2007, 02:04:04 »
I think the leak is going to be from the oil cooler cover or the thermostat housing.
    • E250 Est / Elroq
Re: Drip Drip Drip
« Reply #5 on: 05 May 2007, 07:49:10 »
Cheers, yes the MV6
Coming from somewhere at the back of the engine, dont know where :(
I was starting to think oil cooler area, we will soon see.
Think I will have to join ABS pdq!
ians
  • Reading
Re: Drip Drip Drip
« Reply #6 on: 05 May 2007, 08:53:43 »
Assuming its not a split hose around the HBV  , I also vote for somethingin the valley.
(Your not getting water in the car are you?  in which case it might be heater matrix)
rpont
  • Tadcaster
Re: Drip Drip Drip
« Reply #7 on: 05 May 2007, 11:02:53 »
Could be the coolant bridge gaskets, metal washers with rubber bonded to the inside.
    • E250 Est / Elroq
Re: Drip Drip Drip
« Reply #8 on: 08 May 2007, 07:59:28 »
Ahh well
Bits ordered on Saturday, Wont be here until Thursday!
Thats me stuck in a v6 Cav for the week then...
Ahh well, the stripdown will continue, lets hope its nothing too drastic.
