Author Topic: V6 engine rebuild?  (Read 1863 times)
V6 engine rebuild?
« on: 18 September 2007, 19:56:10 »
I have a spare 3.0 engine, and it looks like I can get some local garage space to store it.
Shall I take it apart, and recondition/rebuild it, and then find a project car to put it in?
maria
  • Derbyshire
  • I'm proud to be welsh :)
Re: V6 engine rebuild?
« Reply #1 on: 18 September 2007, 20:01:12 »
I think you should as you love geting your hands dirty ;D
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #2 on: 18 September 2007, 20:01:44 »
I love rebuilding engines... Replace absolutely everything possible, have the block and heads dipped.
Bright orange Hamerite is your friend :)
    • 530D M Sport, 330i Coupe
« Reply #3 on: 18 September 2007, 20:17:31 »
If you do could I come along and get involved? Like to get messing with a V6 and see what I can learn!
« Reply #4 on: 18 September 2007, 20:24:09 »
I wouldn't want to put new rings in worn bores, presume I could get it re-bored and use oversize rings?
And then - what about bottom end bearings etc....
I'd want to effectively end up with a brand new engine, but I'm wondering whether cost wise, it's feasable.
Re-building heads is easy for me, not so confident with the bottom end tho...
IrmscherKris
  • Manchester
« Reply #5 on: 18 September 2007, 20:27:10 »
The bottom end is a piece of cake (yum)
Undo the rod bolts then push the piston + rod out throught the top - replace the rings
ARP rod bolts are cheap too IIRC  :y
« Reply #6 on: 18 September 2007, 22:40:47 »
Normally a rebore will require oversize pistons as well, and then it gets very costly - probably 70 or 80 quid a piston.
Best to strip it completely, drop off the block, crank and pistons at a decent engine workshop and get them to measure everything and advise on what needs doing. With luck there'll not be too much bore wear so a hone and some new rings will do it. With the promise of supplying all the bearings, etc. for the rebuild they'll probably do all the measuring cheap or free.
Get them to measure the crank journals, and give them a polish while they're at it. If they look out of spec they'll have to be ground down and oversize bearings fitted. Otherwise, just get them to order up the correct size bearings. Not sure if they're one size fits all or graded on this engine.
It can be done with care, and the engine will be as new if it's run in carefully (This means putting it under full load for short periods with time to cool off in between in my book, NOT pussy footing around at sub-3K RPM for 500 miles!).
If it's just rings and bearings that the bottom end needs I'd say go for it. It'll cost a few hundred quid for the bits. If you need to get into a rebore plus new pistons I'd say the cost would make it madness. I did this with my kit car engine due to the ring grooves being a bit wide and it didn't sound too bad until it was all added up, then I felt a bit of a numpty - and that was a 4 pot! Multiply costs by 1.5 for a V6.
It is very satisfying, however, and that's worth something.
You'll have no problems. Just be methodical when it comes to putting it back together, make sure everything is checked for clearance - including piston ring gaps, etc. Get an engine stand to put it on during stripping and reassembly - makes it much easier and you'll end up doing a better job. I've got one you're welcome to borrow.
First step is probably to whip the heads off and see what the bore wear is like. That will determine if it's a go'er or not.
« Reply #7 on: 18 September 2007, 22:49:56 »
I had the heads off this engine a few months ago (you may recall!!) - bores looked fine, no oil at all was used, and engine totally quiet.
Part of me is tempted to focus more on the top end, if the bottom is fine.
Only problem is, if I have a tip top condition 3.0, you know what i'll want to do with it ;D ;D  ::)
« Reply #8 on: 18 September 2007, 23:00:59 »
I'd say if it's a good runner either leave it be or completely rebuild it. Yes, it could probably benefit from having the valves lapped in. With hindsight this would have been easy when the heads are off but it's never the right time when it's an urgent repair, is it? However, it's not worth stripping it, with the cost of another set of gaskets, etc. to do that alone IMHO.
Have you lobbed the cams into the 2.5 yet?  [smiley=evil.gif]
davlad22
  • Sunny Yorkshire
« Reply #9 on: 19 September 2007, 01:31:35 »
 ;D
« Reply #10 on: 19 September 2007, 08:25:47 »
Bore wear on a V6  ;D  Yet to see one with someand if it did hav some then it would be in the bin coz the rest is likely to be shot!
Crank can be checked and measured yourself with good veniers and polishing the journels is easy enough.
Then hone the bores (de-glaze them basicly) and fit new rings having cleaned everything well. New main and big bearings gaskets etc and jobs a good un.....
There are a few interesting things you can do on the way to.....
